Put f22b1 from 95 accord in 1990 accord
Well the motors in but im havin a problem with the harness..the wires n plugs look similar but the engines harness does not plug into the connectors in the engine bay on the left and right side.. only one connector works...now the car just cranks wit no fuel or spark..so should i just replace the engine harness or the harness that runs from the ecu to the engine bay?
http://www.cb7tuner.com/vbb/showthread.php?t=118444
i used stock engine harness from my 92 accord, and not from the f22b1, you should use your old one as well, some plugs will have to be spliced to mate up with the female plugs. make sure your throttle positioning sensor and MAP sensor wires are wired up correctly, or else your car will start up then die immediately.
I used my original harness, with the F22A ERG valve, F22A Map sensor, and ran the wires for VTEC solenoid and pressure switch. The only wiring that needed to be modified was the ignition wiring, which was converting from external to internal coil.
aasaa666
Mar 6, 2008 09:26 PM
