getting hub off front wheel bearing help!
Old Feb 6, 2009 | 06:03 PM
z6hatchboy's Avatar
Default getting hub off front wheel bearing help!
Im replacing the front wheel bearing. We had to get a new knuckle anyways and its wheel bearing was bad so we just took it out and put the new wheel bearing in. How do you get the hub out of the old wheel bearing though. Thanks a lot!
Old Feb 6, 2009 | 06:24 PM
Former User's Avatar
Default Re: getting hub off front wheel bearing help!
Unless you have a press, you will need to take the knuckle to a shop to have them press the hub and bearing out of and back into the knuckle.
Old Feb 6, 2009 | 06:31 PM
z6hatchboy's Avatar
thanks, i seen that in the service manual but the hub press piece didnt register. I knew it had to be pressed out though
Nisif
Dec 4, 2006 04:03 AM
SomeDude56
Oct 30, 2006 10:49 AM
XJamesX
Suspension & Brakes
Jun 1, 2005 12:41 PM
92civeg
Feb 27, 2004 08:32 PM
