>>cluster trouble!!!!! Help!!!!!<<
Old Feb 6, 2009 | 02:40 PM
str8boolinEK4's Avatar
Icon3 >>cluster trouble!!!!! Help!!!!!<<
I HAVE A 1998 CIVIC AND MY CLUSTER STOPPED LIGHTING UP. I CHECKED THE FUSES AND THEY ARE ALL GOOD. I'M HOPING I DONT HAVE TO REPLACE MY CLUSTER LOL..... IF ANYONE KNOWS WHAT THE PROBLEM MIGHT BE LEAVE ME A POST OR PM THANKS.
Old Feb 6, 2009 | 02:41 PM
Default Re: >>cluster trouble!!!!! Help!!!!!<<
help me please help me!!!!!!
Old Feb 6, 2009 | 03:31 PM
JDM94HATCH's Avatar
your dimmer switch might be causing this trying tapping on the dimmer
Old Feb 6, 2009 | 04:21 PM
Thanks......
Old Feb 7, 2009 | 12:18 PM
fcm's Avatar
fcm
Old Fart
Stop yelling we can hear you.
Question, do all the other dash lights work, is it just the cluster illumination that does not?
If other dash illumination lights work, [heater control panel, CC, rear defog, hazard switches and so on] and it is only the cluster illumination that is not working, you will need to pull the cluster and test for power, [when park/head lights are on] on the red/black lead, if there is test for ground on the red lead, [ground potential will change as you rotate the "Dash Lights Brightness Controller.
If you have power, [red/black] and ground, [red] check the bulbs, [although it is unlikely that all 7 have blown at the same time] if they are good check for damage, [burnt traces] on circuit board and make sure the cluster plug(s) is properly plugged in and making a good connection. 94
sol-oto
Jun 17, 2018 08:56 AM
TeeKayy
Jul 19, 2016 11:08 AM
kwae
11
Feb 13, 2014 07:51 AM
haukurn
Dec 6, 2010 05:58 AM
mark11017
Sep 27, 2010 09:17 PM
