Reading codes from check trans and d4 lights?
Old Feb 6, 2009 | 01:16 PM
follie gatts's Avatar
Default Reading codes from check trans and d4 lights?
hi guys. my transmission went "clunk" this morning after driving for about 3 minutes. the car was warmed up for about 10 minutes before moving.
i hear clunk, then my trans light comes on immediately, my speedo dies and my car doesn't switch gears when in d4. it seems like its always in 3rd or 4th because the power sucks. park to reverse is hard. neutral to d4 is hard. real hard shifts. not good.
my transmission fluid was not empty. i added 1.5 quarts and the shifting is the same.
so i jump the service connector wires with a paperclip and these instructions: http://www.modifiedlife.com/how-to-r...acura-integra/
i have no check engine light, but the check transmission light is sending these codes:
20
65
70
repeat
and the d4 indicator light is blinking these codes:
16
repeat
what do these mean? are they the same as if the check engine light was displaying them?
i think i have a major malfunction, here, but i would like to know the code read outs before i start asking who is close to me in 17543 and can help replace the transmission in my 2000 LS.
today sucks, btw. thanks for any info you can provide.
Old Feb 6, 2009 | 02:02 PM
Default Re: Reading codes from check trans and d4 lights?
found this: http://www.troublecodes.net/acura/96-02int.shtml
still not sure if i have a solenoid problem or vss or if i should start shopping for a new tranny
Old Feb 6, 2009 | 04:40 PM
ok, here's a video of my check trans light and d4 light emitting codes.
[youtube]KWRTufin0ck[/youtube]
Old Feb 6, 2009 | 06:30 PM
d2r's Avatar
d2r
I think your tranny about to go out on you
Old Feb 6, 2009 | 07:00 PM
yeah, that's what i think, too. i think the first time it went to 4th this morning is when i heard the clunk and now d4 is fourth gear all the time.
local trans shop told me it could be a simple electrical problem or total loss, just trying to learn a bit more about it. i have the dealer service manual but not the helms.
Old Feb 6, 2009 | 08:39 PM
Originally Posted by troublecodes
P1297 20 ELD Circuit Low Input
P1298 20 ELD Circuit High Input
P0141 65 Secondary HO2S Heater Circuit Malfunction (Sensor 2)
P0700, P0715, P0720, P0725, P0730, P0740, P0753 & P0758 70 A/T
P0131 1 Primary HO2S Circuit Low Voltage (Sensor 1)
P0132 1 Primary HO2S Circuit High Voltage (Sensor 1)
code 20 = Electrical Load Detector
code 65 = Secondary Oxygen Sensor Heater
code 70 = Automatic Transmission Malfunction W/AT Controls
code 16 = Fuel Injectors
code 1 = Oxygen Sensor #1
Joshboom2488
11
Jul 27, 2014 05:50 AM
G. Man
12
Feb 25, 2011 06:13 PM
90dteg
Sep 18, 2008 12:54 PM
Corruption
Jun 3, 2006 12:08 PM
tvrsir
Apr 8, 2002 05:26 PM
