Suspension & Brakes Theory, alignment, spring rates....
Lowering Springs on 2008 Accord Coupe 4 cyl.
Old Feb 6, 2009 | 01:00 PM
AlexcustomRide's Avatar
Default Lowering Springs on 2008 Accord Coupe 4 cyl.
Hi, I want to lower the ride to give a better look, and a better feel on the road. For now, I just want to put lowering springs on my stock shoks, and then may be later upgrade shocks.
I want to know if the ride quality is really that bad with Sportline, compare to Pro kit. (Eibach)
Thanks
Old Feb 6, 2009 | 01:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Lowering Springs on 2008 Accord Coupe 4 cyl.
Do yourself a favor and do it all at once. Trust me, it'll be ALOT less simpler that way. Otherwise you would have to disassemble/reassemble the springs and shocks both times, so it's like you're doing the complete installation 2 times.
Trust me, save your money a little longer and you'll be much better off. You can do it, have patience.
Also Eibach Sportline springs drop quite a bit, and will no doubt blow out stock shocks fairly quickly.
Old Feb 6, 2009 | 02:16 PM
All wright thanks!
Gstowe003
Apr 6, 2010 12:01 AM
Niskyspy
Aug 25, 2007 08:29 PM
spinny
Jan 24, 2005 10:25 PM
Chubakon
Sep 7, 2004 08:18 PM
icechimpee
Sep 12, 2003 07:28 PM
