Fog Light Switch Question (94 Accord)
well a while back i installed some oem fog lights for my 94 accord, but with a autozone kit,, so the fogs are oem but the connection and switch is not......but i just recieved my oem switch today, is there a way to connect it to the current way i have it?? or do i have to get the original harness?
thanks
thanks
This link may help you in wiring the factory fog light switch to your existing aftermarket fog lights without the use of a factory harness.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-fog-light-general-questions-thread-oem-depo-essue-raybrig-password-jdm-ebay-1812043/
oh the kit was a basic 3 wire set black,red,white and with the switch.........it was pilot something....heres a pic of the kit that i used
http://www.jdmuniverse.com/forums/howto/crxfogs/12.jpg
Ah gotca, for something like that you can probably just grab a multimeter on the oem switch. See which pins are closed when pressed (which would complete the circuit and turn it on) I think the OEM one has like 4/5 pins though as it interacts with the headlights and what not. Yours would just be a simple on/off. Let me see if I can snag a diagram for the oem fog switch
copied from a very old post I saved back when I did mine... NOTE: the directions given are for a switch installed upside down so you'll hafta switch the prong numbers accordinly. Fog light switch assembly – part # O8V31-SV4-100R3 Ok first thing you're gonna need to do is cut away the > plastic surrounding the prongs. ok now if you are looking at the back it > should look something like this: > > 1 2 3 4 > 5 6 > > (Each of the numbers stands for a prong) > > Ok Connect the +12 power lead from the battery to prong 1 > > Ok connect the wire from your fog lights that is supposed to be connected > to the battery to either prong 3 or 4 (Prongs 3 & 4 are both copper and > are connected so it really only one connection) > > Ok now you should be able to switch the fog lights on and off > > Ok now connect prong 2 to a ground > > Now connect prong 5 to the dash illumination wire. I used the one on my > head unit, but you could run it to the dimmer switch to the left of the > steering wheel. > > Ok now connect prong 6 is another ground. > > I think that is it, but I'm just doing this from memory. The only thing > I'm not sure if I'm remembering correctly is the last step. It causes > the green light below to light up when the bottom is pushed in, but I > think that what I wrote is right. To connect the wires to the prongs > I wrapped it around them and than bent the prong down over it. Let me > know if it works out.
**** it the board is messed up http://www.hondasociety.com/board/sh...+light+diagram
You should be good, worst case is get a multimeter and see which pins are open when the switch is depressed and closed when the switch is pressed.
got an update....well i followed that diagram and it worked......the only thing i was not able to do was make the switch light up....but other than that it turns off the fogs as well as on........i plan on making the switch light up.....any ideas???
Hey any luck on ever gettin the light on the stock OEM switch to light up?? Im curious to know..
Justin Kershner
Nov 22, 2016 09:46 AM
