Will a shop tap your oil pan.
Old Aug 8, 2002 | 01:20 PM
TheHater
Guest
Posts: n/a
Default Will a shop tap your oil pan.
Thats the only thing im afraid of when installing my turbo kit. Anyways I just want to know if anyone has ever had it done and how much did it cost you and also where did you get it done if you where in cali.
Thanks
Old Aug 8, 2002 | 01:25 PM
supergreenNA1's Avatar
New User
Default Re: Will a shop tap your oil pan. (BOOSTINSI)
in los angeles there are a number of shops you can bring your oil pan and have a nipple WELDED on.
Old Aug 8, 2002 | 01:26 PM
TheHater
Guest
Posts: n/a
Default Re: Will a shop tap your oil pan. (supergreenSol)
I live in LA is there any you know of or anybody out there.
CovertFI's Avatar
earl makes a bulkhead connector just get that. you drill a hole and place it in the hole and put the nut on the back side. so easy.
Old Aug 8, 2002 | 01:43 PM
khang77642's Avatar
Default Re: Will a shop tap your oil pan. (CovertFI)
do you have a website for Earls ?
Old Aug 8, 2002 | 02:05 PM
blkDOHCsol's Avatar
New User
Default Re: Will a shop tap your oil pan. (khang77642)
any muffler shop can do it
Old Aug 8, 2002 | 02:43 PM
CovertFI's Avatar
i dont, but i know someone does have a link.
Old Aug 8, 2002 | 02:53 PM
rjardy's Avatar
bul head connector works just fine, no leaks it installed properly, i havent used one but know people who have and they have zero problems with them.
Rob
Old Aug 9, 2002 | 12:56 AM
CalvitoSol's Avatar
Default Re: Will a shop tap your oil pan. (rjardy)
i got a brass fitting for my pan. any ideas on how to keep it leak free? i was thinking that i can just get a nut on the other side inside of the pan and just put some silicone gasket sealant on the threads. is this a bad idea?
Old Aug 9, 2002 | 01:49 AM
rjardy's Avatar
Default Re: Will a shop tap your oil pan. (theory48)
well my only concern would be that if some of that silicone were to break loose and go into the pan and then get sucked up the sump, it may clog it, but if you use a liberal amount, im sure it would be fine
Rob
Old Aug 9, 2002 | 01:55 AM
CalvitoSol's Avatar
what are some good ways to get the brass fitting on to the pan for a leak-free job?
Old Aug 9, 2002 | 01:13 PM
Etylorcen's Avatar
I dont see why any muffler shop wouldnt do it. Its not like they're messing with the cat or something.
Old Aug 9, 2002 | 01:41 PM
2000Accord5sp's Avatar
Default Re: Will a shop tap your oil pan. (Etylorcen)
or you can buy a moroso oil pan.
Old Aug 9, 2002 | 01:42 PM
zojirushi's Avatar
JB weld
Old Aug 9, 2002 | 04:23 PM
speedymon's Avatar
Default Re: Will a shop tap your oil pan. (zojirushi)
Hell yeah JB weld is the ****!
Old Aug 9, 2002 | 09:58 PM
T25 civic's Avatar
Default Re: Will a shop tap your oil pan. (speedymon)
Or you could weld the piece in, instead of using silicone. Almost any body shop will have a welder that you could pay them to do it for you.
Nick
Old Aug 10, 2002 | 01:48 AM
CalvitoSol's Avatar
Default Re: Will a shop tap your oil pan. (T25 civic)
Nick
not sure but, can you weld brass to a steel oil pan?
Old Aug 10, 2002 | 03:01 PM
true's Avatar
You dont weld brass to steel, you can braze it....it's basically like soldering...it is soldering actually.
Old Aug 10, 2002 | 04:10 PM
CalvitoSol's Avatar
Default Re: Will a shop tap your oil pan. (true)
where can i get it brazed?
Old Aug 12, 2002 | 12:09 PM
civicb18b's Avatar
i am so brazed
bump
JdmMidWest
Feb 20, 2012 05:20 PM
skiwithcars
Jun 20, 2006 07:24 AM
Boosted EM1
Jan 21, 2006 10:51 PM
Turbo_Mike
Apr 19, 2005 11:33 PM
ddong2lee
Feb 15, 2004 04:28 PM
