f22b1 or f20b ?
Old Feb 6, 2009 | 07:29 AM
boostedhks's Avatar
Default f22b1 or f20b ?
I got a 97 accord with an f22b1 in it. I want to boost my car with a goal of 350 whp. Everybody has told me that the f22b1 is better to boost than the h23 because its got stronger walls so the motor's holding capabilities are a lot higher than the h23, Ok. Now, i really want to do a swap to my accord as i want to run a dual cam vtec motor in it and i just found an F-series that seems to be able to get the job done.
I found an f20b in a website. My question is: How good is this motor for boost ? are the walls as strong as the f22b1 or is it the same as the h23 ?
Old Feb 6, 2009 | 12:37 PM
fatboy1185's Avatar
Big Cat
Default Re: f22b1 or f20b ?
DOHC vtec f20b? Iron block, so good for boost, but high compression, so a really good tune is needed. But it would be very repsonsive at low boost. You could get custom pistons made for around $600, which would lower the compression quite a bit, and might be a little more turbo friendly. What are your power goals and spending limits?
Old Feb 6, 2009 | 12:40 PM
TheMuffinMan's Avatar
He knows where you live!
F20B = H22A for the most part, just think of it like that
Old Feb 6, 2009 | 04:53 PM
boostedhks's Avatar
f20b = h22 ok, but is the f20b walls as thin as the h22 one's ? I dont mind spending 4000 for properly boostin the f20b. i just want it to get done right.
Old Feb 6, 2009 | 05:06 PM
It's a destroked H22, so I'm wagering they didn't change anything with it really haha. If you're planning on boosting I would stick with the F22B1 and 350whp is attainable with it.
Old Feb 6, 2009 | 08:58 PM
AP96's Avatar
so the f20B walls arent FRM?
Old Feb 6, 2009 | 09:07 PM
Apparently they aren't, I'll have to correct myself, I was under the impression it was almost identical to the H22A block.
*edit* That's after doing some more searching around on the interwebz, though there seems to be quite a bit of confusion on the subject. Some say they are others say they aren't.
Old Feb 6, 2009 | 09:49 PM
fatboy1185's Avatar
Big Cat
the block is IRON. just like stock f22a single cam's.
Old Feb 7, 2009 | 05:20 AM
Loco-B's Avatar
i havent seen a boosted f20b. not gonna lie. If i was going boost i'd probably go f22b1. If your going NA i'd go f20b.
Old Feb 7, 2009 | 05:44 AM
extralargenog's Avatar
ther block is aluminum, the sleeves are too, the LINERS are Iron.
Bai
Old Feb 7, 2009 | 08:02 AM
Bai
Old Feb 8, 2009 | 01:10 PM
boostedhks's Avatar
so the f20b not good for boost. Damn, i guess i'll stick to the f22b1 then THanks a lot guys.
skylude23
Jan 15, 2007 02:39 PM
NeKe1point0
Sep 18, 2004 08:04 PM
SuperShale
Feb 3, 2004 09:27 PM
psyphre
Nov 11, 2002 07:59 PM
acrdheadturner
May 8, 2002 03:11 PM
