Suspension & Brakes Theory, alignment, spring rates....
H22 Swap? Yikes I am lost.
Old Feb 6, 2009 | 01:42 AM
NiecoJDM's Avatar
New User
Default H22 Swap? Yikes I am lost.
I need the struts and coilovers for a H22 swap into a 93 EG coupe I have ones for the civic but the H22 weighs too much for them so they are blocked out till I can get the right ones please someone post a link up for them I also dont have 2000 dollars to spend on them so if you can help please do!
Or if you have some forsale yourself New or Used it doesnt matter as long as they are in good condition and you can prove it.
Old Feb 6, 2009 | 01:57 AM
92civiceg9gsr's Avatar
Default Re: H22 Swap? Yikes I am lost.
Progress sells lowering springs specifically for a H22 swap.
Old Feb 6, 2009 | 02:12 AM
xd69's Avatar
Your stock shocks not struts are fine iff they aren't blown. If your car seems to low with the H, then just get some higher rate springs. My brother had KYB AGX with Eibach Sportlines (both intended for a civic) and it was fine
acclude23vtec
Oct 31, 2005 04:59 PM
