Sway Bars / Alignment
Old Aug 8, 2002 | 12:44 PM
RedLudeSH's Avatar
Default Sway Bars / Alignment
after upgrading my Sway Bars to ST bars, my alignment is a bit off ... can anyone help with an explanation?? ... thx
GW
Old Aug 8, 2002 | 01:47 PM
norice's Avatar
Default Re: Sway Bars / Alignment (RedLudeSH)
Changing anti-roll bars should not affect your alignment - unless, you were really yanking on the suspension, or removed control arms, shocks, etc. when installing them.
How do you know that your alignment is off?
Old Aug 8, 2002 | 02:35 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Sway Bars / Alignment (norice)
laser eyes .... agreed simply bolting on a sway bar will not affect any settings on aligment.
later
matt
Old Aug 8, 2002 | 03:27 PM
EagleR's Avatar
Default Re: Sway Bars / Alignment (champITR)
How'd ya manage that?
Old Aug 8, 2002 | 05:35 PM
RedLudeSH's Avatar
Default Re: Sway Bars / Alignment (EagleR)
after installing the front sway bar, the car is turning to the right by itself ... don't know y ... the steering wheel is actually turning (a lil bit) ... some times when alignment is off, the steering wheel is straight, but the car is turning ... but in this case, when the steering wheel is straight, the car goes straight ... but i have to hold the wheel there, or else the car will turn to the right ... pls help
GW
Old Aug 8, 2002 | 06:04 PM
Mike P.'s Avatar
25 Year Member
Sounds like you may have installed the bar with some preload while even sitting still. I'd go back and double check your installation, with particular attention being paid to the endlinks. What bar did you end up getting? Also, make sure the bar is centered.
User 12720
Suspension & Brakes
Jan 15, 2009 03:51 PM
jplowman2005
Suspension & Brakes
Oct 31, 2008 05:09 PM
neozero999
Apr 22, 2008 04:39 PM
ziovan
Nov 9, 2007 11:05 PM
RedLudeSH
Aug 8, 2002 12:36 PM
