B17 and NA B parts, built head, EFB mounts etc
Parted most of my stuff out, here is what's left:
Head:
1993 GS-R B17A1 PR3 head
Integra Type R Valves
Skunk2 Prototype Cams, supposedly similar to Toda C or D, 12.5mm lift and 300* on both, model is H20011 from Skunk2
CC Cylinder Head Full Race port and chamber work, includes new valve guides etc (http://cccylinderheads.com/main.html) (retail $845 with valve refacing)
Pics of the head can be found here
B VTEC valve cover, shaved and painted as seen in the linked pics and other pics of my car, $50 OBO
B17A1 block with crank and ARP main studs, new Honda water pump (<10k miles), upgraded oil pump as in my how-to in the FAQ. Pretty much complete minus rods and pistons. It's pretty clean, pics of the build can be seen here.
ARP head studs for B16A or B17A $80
B17/B16 near-new OEM Honda timing belt $20
I will get pics of the parts not in the links at request, and see if I have anything else tomorrow.
I accept pretty much any kind of payment, including credit cards. No personal checks unless it's a local bank and I can cash it.
Asking $900 for the head bare.
Head:
thanks!!
Some pics...
head studs, washers and nuts are in the bag with some other misc bolts:
valve cover on my car, shaved and painted, the cam gears are exposed as well. Plug wires (OEM) and cover also for sale.
the block
header with dents:
intake manifold:
I also found a couple more spares...
New valve cover gasket for B VTEC, I do have the top metal washers too, forgot to put them in the pic:
Some pics...
the block
header with dents:
intake manifold:
Ok sold the baffle plates as well now, I'll update the first post. Also have a Vortech fuel pressure regulator that was on the rail that I forgot about.
