92 civic; lots of white smoke
Old Feb 5, 2009 | 04:02 PM
buddy190's Avatar
Default 92 civic; lots of white smoke
I just got done tuning up my cx, and the ****er starting smoking worse than before. I changed the spark plugs, cap/rotor, valve cover gasket/O-rings, brand new duralast battery; I put restore in with some cheap motor oil and let it run for a good half hour before flushing and refilling with castrol 5w-30. I ran the motor for about 15 miutes after that, checked the oil and its ****ing clear. Its hard as **** to read the dip-stick. But it died once while I was backing into my yard. And there is just a ton of white smoke. Could there be a reason Im not aware of for all the smoke? I'm hoping its just be the restore or maybe the excess oil burning off the pistons. Any input would be greatly appreciated.
Old Feb 5, 2009 | 04:04 PM
nengx07's Avatar
Default Re: 92 civic; lots of white smoke
yea if u get any info tell me also... same problem..
Old Feb 5, 2009 | 04:05 PM
Rev2 9K's Avatar
check you coolant level, might have a bad headgasket, this is what my dx was doing also, took the head off and the gasket was all f***ed up. Now it runs great.
Old Feb 5, 2009 | 04:23 PM
buddy190's Avatar
ugh. Good thing its a single cam.
Old Feb 5, 2009 | 04:28 PM
nengx07's Avatar
does urs leak on the outside or just white smoke from exhaust??
Old Feb 5, 2009 | 04:46 PM
buddy190's Avatar
Well, Ive only had the car for three days. The only leaks I knew of were from the valve cover gasket, O-rings and the rubber and brass things on the top of the valve cover, and I fixed all those. **** was all just hand tight. The previous owner was stupid about cars. He used SuperTech brand for EVERYTHING he could. Even the oil filter. Its not surprising that the car is in such sad shape after only 90,000 miles.
Old Feb 5, 2009 | 04:53 PM
nengx07's Avatar
yea ill tell u after i replace my headgasket see if mines stop smoking.. i replaced same things u did n still same problem LOL
Old Feb 5, 2009 | 04:58 PM
buddy190's Avatar
yea, keep me updated. Ill check my coolant, and eveything else while Im at it, tomorrow. Who knows what else is broken with supertech's crap in and on the car...? If I figure it out, Ill post it up.
Old Feb 5, 2009 | 05:09 PM
nengx07's Avatar
alright... ill be taking apart my head tomorrow.. should be done by around this time tomorrow.. ill let u know
Old Feb 5, 2009 | 05:26 PM
green-'s Avatar
You have oil on the manifold
Happiest92Ricer
13
Apr 30, 2013 06:43 PM
JunkyardAccord
Nov 18, 2008 10:11 AM
PRIMITIVEALLMOTOR
Engine Management and Tuning
Aug 23, 2008 01:44 PM
cars101
20
May 6, 2007 02:38 PM
Broken Gearbox
Aug 8, 2003 09:00 AM
