i need brake help 95 civic
Old Feb 5, 2009 | 03:26 PM
dave181's Avatar
Icon2 i need brake help 95 civic
i have a 95 civic and my brake pedal would sink in when applied i changed my front brake lines and bled the system still no sank and i chekd the master and it was bad so i changed it along with the brake booster now i have no brake period i dont know whats rong if any1 has an idea or had same problem leave feed back thank you
Old Feb 5, 2009 | 04:45 PM
Former User's Avatar
Default Re: i need brake help 95 civic
Did you fill the master cylinder with fluid and rebleed the hydraulic system?
Old Feb 5, 2009 | 05:35 PM
Jimmy's Avatar
Global Moderator
^ x2.
What bleeding procedure are you using? I'm sure there is a bunch of air in the lines..
Bleed the brakes, bleed them again.. and again.. and you should get some pedal feel
Old Feb 5, 2009 | 06:01 PM
Inliner's Avatar
get a vacuum bleeder from your local auto parts store start at the pass rear then driver rear then pass front then finally driver front and make sure the master never goes dry get at least a quart of dot 3 brake fluid.
curtie94
Apr 9, 2011 05:01 PM
boostedteg1203
Jan 21, 2010 05:58 AM
dgdarien
Sep 25, 2009 06:25 PM
The Hooligan
May 5, 2005 03:32 PM
Volcom
Mar 16, 2002 09:04 AM
