B18A1 into CIVIC 92-95 ??HELP PLEASE!
Old Feb 5, 2009 | 02:29 PM
krysted9354's Avatar
Default B18A1 into CIVIC 92-95 ??HELP PLEASE!
ok, i just got a brand new rebuilt b18a1, and have my blown d15b8 93 civic cx,
What all do i need to swap it into my 92-95 ??
please make me list, thanks VERY MUCH !
Old Feb 5, 2009 | 02:32 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: B18A1 into CIVIC 92-95 ??HELP PLEASE!
Have you searched? The FAQ more than likely will answer any/all questions you may have.
Old Feb 5, 2009 | 02:38 PM
yes i have but many people say a z6 would be tha same hp but this b18a1 is built and will get boosted, so
CAN SOMEONE PLEASE send me a list of what i need , like ecu ,axles,shaft,mounts,harness etc ?
Old Feb 5, 2009 | 02:44 PM
24TEN's Avatar
PHANTOM MENACE
Dude, you just made your own list!
Old Feb 5, 2009 | 02:57 PM
SinsEvil666's Avatar
Yes, we cant help u if u cant help urself....check the very top of this section....specially the FAQs...u will find everything u need..
Old Feb 5, 2009 | 02:59 PM
this is for a b18c1 swap...very alike.....
http://www.c-speedracing.com/howto/b18cswap/swap.php
and this is the link for the FAQS (located at the very top)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Old Feb 5, 2009 | 04:05 PM
yeah but what i looked 1 hour and cant find is the motor if from a 90-93 obd0 b18a1, so which ecu ? mounts ? axles and wiring harness ?? i know b18b or gsr swaps but this ?
Old Feb 5, 2009 | 04:08 PM
1992Si's Avatar
hondaswap.com
may be...?
Old Feb 5, 2009 | 04:48 PM
24TEN's Avatar
PHANTOM MENACE
90-91 is pre-OBD, 92-93 is OBD1. Which ECU you'll need will depend on which OBD version you'll be using. The other questions you have are answered in the FAQ.
Old Feb 5, 2009 | 06:00 PM
can find info please help, also how do i tell if the block is 90-91 or 92-93
Old Feb 5, 2009 | 06:08 PM
94EG8's Avatar
Seagull Management
Correct
Unless the OP is completely retarded he'll be running whatever version he has as OBD1.
Old Feb 5, 2009 | 06:10 PM
94EG8's Avatar
Seagull Management
Stamp in on the head above the cyl 4 exhaust port. If it was a '93 the stamp would look like this: 9/3.
Old Feb 5, 2009 | 06:42 PM
iliv2xlr8's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/dans-massive-obd2-b18b1-into-1992-civic-cx-hatch-write-up-2239971/
Old Feb 5, 2009 | 07:46 PM
94EGKUSH's Avatar
*Hydro B series tranny
*DC 94-01 Shift linkage
*DC 94-01 Post Mount/Silver mount(driverside)
*DC 94-95 LS ECU P75
*DC 94-01 Half Shaft/Axels
*DC 94-01 Fuel Filter to Fuel Rail Fuel line
*Reuse your Engine harness
*OBD1 b series IM
Thats basicly all besieds oil,filter, ect.
Lmk if im missing anything
Old Feb 6, 2009 | 08:44 AM
CivicSpoon's Avatar
^ also a '94-'01 Integra rear mount bracket.
spoonsports12
May 29, 2008 10:36 AM
spoonsports12
Welding / Fabrication
Apr 12, 2008 01:55 PM
PreludeDude96
Jan 22, 2005 07:34 PM
HatchbackSiVtec
Aug 9, 2004 10:57 PM
