D Series Transmission Quest. - DX - EX?
Old Aug 8, 2002 | 12:05 PM
alphaquake's Avatar
Default D Series Transmission Quest. - DX - EX?
i have a mini-me setup of a d15b7 bottom and a d16y8 head. suprisingly i feel the difference after the head swap, and love it, but I know i would feel a greater change if i get a new clutch. right now i have a burn't clutch and what i want to know is whether should i get a d16z6/y8/EX tranny or just put a 6 puck in the d15. i am totaly enjoying this D series ****.
thanks
Old Aug 8, 2002 | 12:24 PM
RR98DX's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (alphaquake)
get the EX tranny, trust me on this.. i just put one in and it made the WORLD of a difference.
Old Aug 8, 2002 | 12:44 PM
vivid02's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (RR98DX)
Go get the ex tranny. It has better ratios and will make a big difference.
Old Aug 8, 2002 | 01:08 PM
stangkilla's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (vivid02)
hey i have the same motor how hard was it putting that 1.6L head on there
Old Aug 8, 2002 | 01:16 PM
D-Man's Avatar
EX all the way
Old Aug 8, 2002 | 01:42 PM
Pengo's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (D-Man)
ex/si is the best
alphaquake's Avatar
not really, just have every part in hand.
cool, EX tanny it is........thanks
[Modified by alphaquake, 10:43 PM 8/8/2002]
Old Aug 9, 2002 | 02:27 AM
D16Z6racing's Avatar
Get the EX/Si tranny, My ATC 6 Puck has just eaten its third tranny. My $.02
Old Aug 9, 2002 | 04:11 AM
EKB18BPR3's Avatar
my vx trans SUX!
Old Aug 9, 2002 | 04:24 AM
TurbodCX's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (dniedacess)
is anybody interested in a SI/EX tranny??i will take $200-250 shipped to you door.
i have got one, i have also got a DX tranny if needed.....
IM for more..
thanks
brian
Old Aug 9, 2002 | 02:35 PM
Mista Bone's Avatar
D Tranny Guru
DO NOT use a 6 puck clutch!!!!!!!
They eat trannys for lunch!
A stock clutch is plenty for a NA SOHC motor.
It will hold 190 crank hp with ease.
I'm now using a USED centerforce dual frictoin unit.
[Modified by Mista Bone, 6:35 PM 8/9/2002]
Old Aug 9, 2002 | 02:39 PM
jdmillusion's Avatar
i've heard of an ex with a 1st gen si final drive. that would be twisted.
and oh one thing:
can you name all the parts switched out on your mini-me? everything...
it'd be great if you can break down details on the swap itself. trying to do one for my brother. i'd really appreciate it. thanx.
[Modified by jdmillusion, 3:41 PM 8/9/2002]
Old Aug 9, 2002 | 08:07 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: D Series Transmission Quest. - DX - EX? (jdmillusion)
you might have heard, but have you driven?
It is impossible to have such a combo.
Old Aug 11, 2002 | 04:31 PM
oldskool_rex's Avatar
I can set you up with a SPRUNG 6-puck. All the hold of a 6-puck, but better drivability. Easier on the trans too...
oldskool_rex@hotmail.com
[Modified by oldskool_rex, 5:31 PM 8/11/2002]
Old Aug 12, 2002 | 04:40 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: D Series Transmission Quest. - DX - EX? (oldskool_rex)
but they will still explode the tranny.
No need for a 6 puck till 250+ whp
Old Aug 12, 2002 | 04:55 AM
Pengo's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (Mista Bone)
hey bone, you mentioned the ex/si can hold up to 190. do you mean that this is the max power the stock clutch can hold? what should be the most reasonable step up after stock? thanks
Old Aug 12, 2002 | 07:16 AM
Crazydave's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (Pengo)
Dont' get the 6-puck...even a sprung clutch is still an MAJOR PAIN IN THE ***
it is drivable (I do it) but it chatters and does nothing but **** me off.
If you aren't making the power to need it don't get it.
When I do it again.. I'm gonna get another stock clutch
Old Aug 12, 2002 | 07:19 AM
98slvrcx's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (Crazydave)
how hard is it to replace the tranny on a 98cx .
Old Aug 12, 2002 | 10:07 AM
eg6ajk's Avatar
Default Re: D Series Transmission Quest. - DX - EX? (98slvrcx)
tranny is no more then 8hr. job even if you are learning and not using power tool.
check the url for clutch/flywheel combo
https://honda-tech.com/zerothread?id=251280
Old Aug 12, 2002 | 12:34 PM
glagola1's Avatar
Hey mister bone, I've got an Apexi turbo kit on my D16z6 and I'm running 6psi. I've seen this equate to 170 whp on two separate articles. My clutch slips like a bitch. It holds once it grabs but it takes time for a redline shift outta first to grab and forget about chirping the tires.
Just thought you'd like to know.
Old Aug 13, 2002 | 01:59 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: D Series Transmission Quest. - DX - EX? (glagola1)
once you glaze the clutch, it is toast.
Old Aug 13, 2002 | 05:56 AM
sweet's Avatar
the EX has closer gear ratios so it will accelerate faster than the DX, though having a high rpm in 5th on the highway which equals more fuel comsumption.
later
Old Aug 13, 2002 | 08:11 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: D Series Transmission Quest. - DX - EX? (sweet)
does it equal higher gas consuption?
Go test and tell me.
I say your wrong and mileage will increase 2-3 mpg.
I only did this tranny swap about 4-5 years ago
Old Aug 13, 2002 | 10:08 AM
Jwcivic's Avatar
If have a 96DX will a 96+ex tranny help me at all?
anyone know the speeds each gear of the ex goes up to?
JAmes
Old Aug 13, 2002 | 02:37 PM
Jwcivic's Avatar
does a 99-00 si tranny fit in a 96dx ?
