Headlight
Old Feb 5, 2009 | 01:08 PM
vodkaTM's Avatar
Default Headlight
Hello,
Was wondering if anyone knew if there is any way to take off the outside cover of the headlight. It seems moisture or something got inside the cover and turn it sort of yellow-ish. I was going to try and clean it but it looked like it was sealed.
Also, if anyone has any cleaning tips would appreciate it.
THANKS!!
Old Feb 5, 2009 | 01:13 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Headlight
Helps to know what kind of car.
Generally toss them in the oven at I believe it's 200o for a little bit and it will loosen up the glue that holds the lense to the light.
Brad_and_the_acc's Avatar
There is a write in the FAQ`s section on the DIY Black housing headlights. That will explain the way to remove and take apart headlights.
Simple procedure.
Old Feb 5, 2009 | 01:20 PM
vodkaTM's Avatar
Thanks for the help guys.
Old Feb 5, 2009 | 01:55 PM
NP man. GL
dso
Acura TL, RL & ZDX
May 26, 2009 10:08 PM
Roybal 3
Aug 18, 2008 12:37 PM
et-s-m-c
Jul 18, 2008 06:41 PM
()0()Miklo
Oct 19, 2007 01:14 PM
rota power
Jun 17, 2006 06:02 PM
