Where do i hook up the vtec oil pressure on a vtec head???
i already added the wires to the ecu, for the vtec solanoid and the vtec oil pressure (on b16, b18c or h22a) ... i found the solanoid on the engine.. but where is the vtec oil pressure??? any links?? pics??
thanks
thanks
yeah.. is that the oil pressure or the solanoid??? or are both of them in the same plug??? the one in the head im using (h22a usdm) has that plug but only one wire is going into the head so i thought its only the solenoid... i dont have the other plug that comes from the ecu.. so i just made my own connection... do i put both the solenoid wire and the vtec pressure to that same plug/????
thanks
thanks
Ehhh?!? No, you connect the oil pressure switch to the pinout on the ECU and the solenoid to the other pinout on the ECU. The plug going into the block - the two-wire plug - is the oil pressure. The one-wire plug going into the cylinder is the solenoid.
i got it all in the ecu and the solenoid., except that i cant find the plug going into the block, the two wire plug, for the pressure... do u have a picture of that??? or can you describe where i can find it??
thanks
thanks
vtecn8ive
22
Aug 3, 2005 01:06 PM
dseriessol
Feb 27, 2004 12:07 AM
