Street Tire options
Pirelli P700Z's. Only come in 195/50/15 and 205/50/15. STICKEY! Great in the rain and even pretty good in the snow. http://www.tirerack.com. They are under $60 a piece.
Later.
Later.
For Street tire on stock wheels:
Bridgestone RE010 195-55-15 can't be matched. Any other 195-55-15 won't be as good. If going with 205-50-15 - i wouldn't recommend that size for 15x6 rim.
I have 205-50-15 S-03's on 15x6.5 right now and its still feels kinda sloppy. It has stronger sidewall than RE010, it also seems wider than other 205 tires, therefore I would recommend at least 15x7 rim for S03's. They don't wear out as fast as RE010, have great wet traction. I wouldn't even try these on stock wheels, these who tried happy with it, fine with me. I tried toyo v rated 205-50-15 - the worst tire yet, soft sidewall feels very sloppy. They do have decent road grip in straight acceleration.
btw.. S-03's in 195-50-15 do not match "max load" per tire. - it might not be safe
Excluding racing tires, you will have better handling when tire size/wheel size matched well, Honda did great job with RE010 with 15x6 - If there is a better tire for that wheel, it would have to be same size as RE010.
Potenza SO-3's in 195/50. Better all around than RE010's and $86 at tirerack.
Yeah ok.
"btw.. S-03's in 195-50-15 do not match "max load" per tire. - it might not be safe"
Yeah ok.
I made some phone calls today And found someone selling Toyo T1s they have less then 1000Km on them and he wants 200 canadian $ (about 120 $ ) for all 4. The thing is they are 205/50-15...witch are recommended for 6.5'' wheels. But as some of you mentioned it is better to keep 195/55-15 on stock wheels. My question is will performances suffer alot? Could it be dangerous or something?
I would really like to buy those tires since i'm on a tight budget at the moment...I'd at least keep'em till the end of summer.
Do you guys think I should do it?
well that seems like a good deal i got my T1s 195-55-15 last week for 759 CAD with balance and mounting and tax.. so i guess it's about 506 US for all 4
I would really like to buy those tires since i'm on a tight budget at the moment...I'd at lest keep'em for the end of summer.
The S-03 195/50R15 is perfect for stock rims, if you don't mind the speedo inaccuracy.....
Dunlop SP Sport 8000's, been runing them on the street for a couple of months now and i am really impressed with them on a dry road, haven't had the chance to test them out in the rain yet.
