Big Brake camber problem
Old Aug 8, 2002 | 10:41 AM
Speed PHreak's Avatar
Default Big Brake camber problem
Here is the deal. I've had my big brake swap. Which is:
90-91 EX knuckles, rotors, calipers
HF Upper A-arms
HF LCA's
Now I've had a camber problem even since I did the swap. At the stock hieght I have postive camber. My tires looks like \ / (not that bad tho). So this wears my tires like hell. I've tried lowering the front-end down but it doens't help any.
Doesn't anyone hav any suggestions on what I should do?
Old Aug 8, 2002 | 10:44 AM
Mugen Dom's Avatar
Default Re: Big Brake camber problem (Speed PHreak)
sure they are ex?
Old Aug 8, 2002 | 10:47 AM
Default Re: Big Brake camber problem (jdmb18hatch)
They could be 90-93 'teg I suppose.....I'm pretty sure they're 90-91 EX
Old Aug 8, 2002 | 10:59 AM
keithv's Avatar
from all that i have read (i don't know from personal experience), the 90-91 ex knuckles do not cause positive camber problems on the EF.
i have heard that the 90-93 teg knuckles will cause a positive camber problem on the EF. seems like you might have the 90-93 knuckles.
Old Aug 8, 2002 | 04:49 PM
crxjdmsir's Avatar
Can you show us pics? It sounds like you are using Integra knuckles. If they are they will look much fatter or wider than the Civic/CRX ones. Also look on the side for a #. What is it?
Old Aug 8, 2002 | 07:05 PM
xXx Justin xXx's Avatar
just slam it more
nihad
Jul 16, 2009 01:48 PM
sportyaccordy
Suspension & Brakes
Apr 17, 2006 01:01 PM
rexnst9
12
Sep 9, 2004 11:06 AM
Chris
13
Dec 8, 2002 07:55 PM
Dano
Jun 14, 2002 10:45 AM
