Turbo Shaft Play
Ok, heres the deal.
I bought a used t3 t4 turbo on ebay.
When i got it, the shaft would not spin, and could not check for play.
Opened the turbo, and has oil in the exhaust side. alot.
The pan had cooked oil/caked up.
So i cleaned everything with purple blaster and thoroughly washed with water.
Mocked up everything, just snug the compressor wheel nut on.
Housings just on, not even on tight, but flush.
Now there is up and down play, a fair amount.
Seems like from the center journal bearings, is this possible?
Or is the thrust bearing responsible for this play?
could the play be coming also because the turbo has no oil inside it?
TheShodan
Jun 8, 2013 05:27 AM
