swapping auto to manual, need some help
Old Feb 4, 2009 | 07:23 PM
cehcivic15's Avatar
Default swapping auto to manual, need some help
92 with f22a6 putting in 91 manual tranny, we didnt take the parts off of the donor car so i need a little help here, the vss has two hoses coming off that are cut, where do those go to? is the vss supposed to be electical or cable? i think the manual looks like cable and havent removed the auto yet but i thought it was electrical.
i can reuse my auto ecu right? the only prob will be a check engine light?
i searched and read the how to, but the guy was doing this swap with a 97 and had to drill holes and redo mounts, but to my knowledge, gen4 accords auto or manual have the same tranny mounts is this correct?....and the holes and things are already there for all the stuff like clutch master cylinder and so on
im helping a friend do this to his car i am a civic guy so my knowledge on accords is limited
if anyone can think of anything else about this swap that might be different from doing this to a 97 please add and i appreciate the help, i think i have all the wiring down except if there might be a difference since im putting obd0 tranny on this obd1 car....thanks again
Old Feb 5, 2009 | 12:28 PM
cehcivic15's Avatar
Default Re: swapping auto to manual, need some help
bump
Old Feb 5, 2009 | 06:44 PM
cehcivic15's Avatar
bump for help
Old Feb 7, 2009 | 08:14 AM
cehcivic15's Avatar
bump for any ideas
Old Feb 7, 2009 | 08:40 PM
cehcivic15's Avatar
ok both trannys have the same vss electrical...
does anyone know where the two hoses going to the vss go to?
black0hatch
Jan 29, 2010 04:59 AM
uenolove
Feb 27, 2008 04:32 PM
IMPORT_IMAGE
Oct 23, 2007 12:31 PM
quik1
Dec 23, 2005 10:22 PM
95civic17
Jul 26, 2002 04:34 AM
