Wiseco Pistons
Old Feb 4, 2009 | 05:20 PM
honda_guy58's Avatar
Default Wiseco Pistons
I am about to order some pistons but I was just wondering if I would have to order them b18c5 specific? All it gives the option for is b18c.
Old Feb 4, 2009 | 05:24 PM
gogetta's Avatar
Default Re: Wiseco Pistons
They are both the same once you start talking aftermarket pistons.
Old Feb 4, 2009 | 05:31 PM
Redcoupe's Avatar
Generally yes.
For your application, yes.
Old Feb 4, 2009 | 05:38 PM
OK thanks, I was just curious because CP and JE pistons have the pistons for every specific B motor on there catalog but wiseco jjust sayd b18c
Old Feb 4, 2009 | 05:42 PM
Redcoupe's Avatar
Are you doing a turbo build, na build or just a rebuild?
Old Feb 4, 2009 | 05:45 PM
Well I am doing a rebuild because my car smokes like hell but while its apart I want to upgrade the pistons and because I want to do a mild all motor build.
Old Feb 4, 2009 | 09:01 PM
Redcoupe's Avatar
I'm not trying to stray you from what you want but look into oem pr3 or p30 pistons.
They offer a little bit higher compression, about the right amount needed for the street, and have the oe tolerances.
IDK if you've ever heard a built motor start up or had one but I don't like to daily drive a built motor. I've done it, got 20,000 miles outta one. They are a bit more noisey than factory.
hovic
Feb 25, 2007 06:47 AM
99REDGSR1
Apr 26, 2004 07:03 PM
austrian type-R
Jan 14, 2002 08:44 AM
