larger than 195/45/15 w/ low offset wheels on ef??
Old Feb 4, 2009 | 04:19 PM
GroundZer0 336's Avatar
Default larger than 195/45/15 w/ low offset wheels on ef??
most of what ive seen on here with low offsets is 195/45/15's, jw if anyone is running anything wider, or taller. maybe 215 45 or 205 50's. i guess between 25 and 15 offsets??? i bought some 195/45s for now untill i can figure out how much room i will have with my 15x8 25offsets, and i have some 10mm spacers laying around to stick it out a little more.
Old Feb 4, 2009 | 07:56 PM
mitsubishiv5's Avatar
Default Re: larger than 195/45/15 w/ low offset wheels on ef??
damn dude your crazy to be running spacers on rims with that much offset. my 15x8s already stick out a little tiny bit. id say no spacers and run a mild stretch. but if your trying to make fast turns run the recommended tire width for a 8inch rim. which i believe is 215. ima try to use 205 but i need to see pictures of it.
Old Feb 5, 2009 | 01:12 PM
well i just mounted my 195 45s today at work and its barely stretched even a little. i dont think its crazy, itl just stick out alot haha. im going to try it with the spacers first then if i cant get them in the fenders ill take them off. just waiting on my coilovers to get here and i can sit the car back on the ground.
Old Feb 5, 2009 | 01:31 PM
nsxtasy's Avatar
H-T Order of Merit
Those tires should NOT be mounted on 15x8 rims. The rims are TOO WIDE for tires that size. 195/45-15 is usually only approved for mounting on rims 6.0-7.5 inches wide. Mounting them on 15x8 rims is UNSAFE because heat and stress can build up in the sidewalls, leading to the tire popping the bead or a sidewall failure. DON'T DO IT.
2000EJ8
Suspension & Brakes
Mar 17, 2009 10:42 AM
CWBETB
Apr 19, 2007 04:52 PM
Rob.
Mar 20, 2006 12:53 AM
whacking stick
10
Jun 14, 2005 02:39 AM
SpoonPL
Jan 12, 2002 05:30 PM
