RBC vs RRC: A visual comparison
I thought I'd share my views Between the 2006 Si manifold and the 2007 Type R manifold
^Something I forgot to add, the overall length or height is shorter on the RRC, so this means that the runners are shorter but in this you can see they are straighter too.
It is a direct bolt on, but sensory wise it MAY not be. Since this manifold doesn't use IACV port like the RBC, I wonder how this aspect would be handled.
with DBW I don't see how you would need IACV port seeing how the ECU can control the butterly plate.
The Si manifold is the SAME casting as the Euro R unit except the Euro R has a K20A2 TB flange bolt pattern.
i would like to get more info on the sensoring of the intake manifold because i would like to see if actually produces a gain that is worth actually buying one. Great info too!!
does anyone kno it you would yeild a power increase from this? If so i may buy one. Looks like a pretty simple swap unless there is something im missing...?
[QUOTE
The Si manifold is the SAME casting as the Euro R unit except the Euro R has a K20A2 TB flange bolt pattern.[/QUOTE]
this is not true i have a euro r t/b and it bolts right to my rbc
not true cause i had got the euro r im from locash years ago before the fg si was out , and i did my swap before karcepts came out with the adapter for the t/b so i used a accord t/b with a throttle cable bracket , sold that set up got a new rbc from the dealer and got a euro r throttle body and bolted it on
Bro, How many times do I have to say idle control is maintained by the DBW and the computer adjusts the butterfly plate opening.
I have a customer I already installed this on and dyno'd
This is a straight bolt on
so it would be cool to run a rbc gasket?
Yeah, 02-09 Civic Si gasket is golden. Chill out? I'm not even upset, don't know how you could come to that deduction over the web.
ok cuz i have 2 rbc gaskets from honda. and im using them both.
i dont think i need to replace the gasket cuz its only been used for a couple thousand miles
