Push lock fittings?????????????
Old Feb 4, 2009 | 10:34 AM
JBLAZE622's Avatar
Default Push lock fittings?????????????
i'm going to be using push lock fittings and hard line for my Vac hoses i was wondering what size fitting do i use on my tial WG and BOV the size is very similar to the 1/8 NPT but i was'nt sure if i could use that or do i need a certain metric size
Old Feb 4, 2009 | 10:44 AM
redboost10's Avatar
Default Re: Push lock fittings?????????????
they do make metric 10x1.0 if im not mistaken, but 1/8npt works just great.
also there was a thread a while back that stated the all steel bodied ones tend to lose their "grip unlike the plastic ones. I think a few people mentioned that.
Old Feb 4, 2009 | 12:20 PM
MrParks's Avatar
tial uses a metric 10mmx1.0 but 1/8npt will work just fine and will not damage the wg.
Old Feb 4, 2009 | 12:38 PM
RedneckRicer's Avatar
In the RV industry we use brass push locks with locktite for all our air ride systems. work very well and very reliable. we get ours from A-1 fittings.
Old Feb 4, 2009 | 12:45 PM
1992Si's Avatar
If you use pipe thread fittings make sure you do not over tighten them.
Old Feb 4, 2009 | 11:44 PM
V-SPEC 1's Avatar
what size line are you guys usually use? 6mm id or is it bigger/smaller than that.
Old Feb 5, 2009 | 05:47 AM
sgnlab's Avatar
Hit up jos from tempest he has made a kit with all the right parts. I just got mine if from his and it is awesome takes the guess work out of this push lock fitting thing. You know his work so why won't they for you.
Old Feb 5, 2009 | 07:57 AM
JBLAZE622's Avatar
i'm gonna use 1/4 hose and teh fittings are cheap like $2 each for 90' and prolly cheaper for straights
Old Feb 5, 2009 | 08:59 AM
redboost10's Avatar
just be sure to get the higher heat resistant hose, i think mcmaster has some that goes up to 180*
Old Feb 5, 2009 | 11:32 AM
slowwhitehatch's Avatar
there's a place here in Milford,CT that has them and they r cheap no more than a dollar a piece the name of the place is (www.Preferred products design. com) check them out.
Old Feb 5, 2009 | 01:21 PM
sgnlab's Avatar
Take the guess work out of it!
Old Feb 5, 2009 | 03:32 PM
JBLAZE622's Avatar
so are the plastic fittings that much better i bought a few brass ones already but i'll just eat the $20 and buy plastics ones if there that much better
Old Feb 5, 2009 | 03:42 PM
MrParks's Avatar
another option would be FCS inc.
they have a complete kit to plumm your twin gates, bov, boost solenoid, vaccum reference, and boost ref. all in one kit. they only use d.o.t approved air brake line from the fittings to the firestone 1/4 air brake line. also offer a nomex fire sleeve to cover the lines high temp areas.
also carry brass i you like
FCS inc has been making a dual wg kit for a bit now.
for more info please email them.
info@fluidcontrolsolutionsusa.com
Old Feb 5, 2009 | 03:58 PM
is that the stiffer version or rubber like material?
Old Feb 5, 2009 | 03:59 PM
T4eg's Avatar
x2 ive got them for joe for alot of cars, never had any problems, using them on my car almost 50lbs of boost and no problems
Old Feb 5, 2009 | 04:02 PM
K20Ahondas's Avatar
50lbs? oooooh man
Old Feb 5, 2009 | 04:08 PM
T4eg's Avatar
said almost :p
Old Feb 5, 2009 | 04:22 PM
Boner_Ben's Avatar
Originally Posted by T4eg
said almost :p
Hah I knew it! Gonna pick up one of these on my next trip to Tempest, alot easier to work with than braided line everywhere (and cheaper too).
Old Feb 5, 2009 | 05:00 PM
sgnlab's Avatar
By the way Joe nice label!
Old Feb 5, 2009 | 05:33 PM
ChokeOnMySmoke's Avatar
Someone Pm me looking for this kit. I want to have everything needed to run it. Thanks in advance.
Old Feb 5, 2009 | 05:40 PM
narfdanarf's Avatar
+1 I want a set of these much easier to buy a "kit" than piece it all together myself.
Old Feb 5, 2009 | 05:57 PM
redboost10's Avatar
its not that hard to piece it together, figure out where you need y's, t's, straights, 45's, and 90's...
at work we have noticed that the brass ones get some "play" in them and kinda loose their grip on the hose
Old Feb 5, 2009 | 06:02 PM
rota92
Guest
Posts: n/a
If you're ballin out of control, check out Legris for full stainless. I may be able to afford one of them if I'm lucky haha
Old Feb 5, 2009 | 06:07 PM
push locks are great our air ride systems/air brakes on the RV's at 120-135 psi no leaks and they see 100x more mileage than our cars
Old Feb 6, 2009 | 12:15 AM
V-SPEC 1's Avatar
what's the fitting size that comes w/ the tempest kit? are they the 10mm x 1.00 thread? or the sae standard 1/8 npt's.
