FS: Full D16Z6 swap
I have for sale a D16Z6 I pulled out of my 93 civic coupe at 206k. When it was in the car it pulled great and ran well. It has NGK plug wires and a new timing belt. It does leak a little oil from the head gasket by the dizzy but it does not burn oil. I put a new head gasket on about 6k miles ago and had the head milled. It had a low idle but I believe it was from a vacum leak some when on the car because the new motor i swapped in has the the same problem. The only problem with the trans is that the reverse switch is bad and your back-up lights will always be on. Other than that it does not grind or pop out of gear. The clutch looks good with id say 50k+ miles left on it. Im selling everything included in a swap: motor, trans, axles, shift linkage, ecu, wiring harness, mounts, etc.. Im asking 400 and I will sell parts individually.
Yea I can do that, just let me know what you need and ill shoot you a price. I'm asking 250 for the long block(block, head, im, tb, dizzy, alt, harness, and sensors). I have this posted up in a couple other places and ive had a lot of offers on it so its not going to last much longer. Its going out tomarrow afternoon.
jdmb16integra
Jun 4, 2005 03:00 PM
