need help with a rear disc conversion help!!!
Old Feb 4, 2009 | 07:01 AM
jdmem126's Avatar
Icon6 need help with a rear disc conversion help!!!
I wanna install some gsr rear disc on my civic but don't know were to start if you know a link were I can see pics on installing them step by please let me know thanks
Old Feb 4, 2009 | 07:41 AM
94EGKUSH's Avatar
Default Re: need help with a rear disc conversion help!!!
its only like 5 blots plus the e brake cable bolts.
if you search youll find it!
I did it on mine and it was easy!
Old Feb 4, 2009 | 07:44 AM
TheRappist's Avatar
What year civic and model do you have. If you want to do it right, ignore the post above.
You will want the full rear conversion trailing arms etc.
Brake cable.
Master cylinder (depends on the year and model civic you have, might not need)
40/40 prop valve
Old Feb 4, 2009 | 07:48 AM
94EGKUSH's Avatar
FYI i got all that, of what you mention it was still plug and play!
stop taking out your *** if you dont know.
What you would need:
Trailing arms
Rotors
Calipers
pads
40/40 valve
new bushings
I just bought mine off here and swaped them on. they had good bushings and awsomes pads/rotors. thats my .02$
Old Feb 4, 2009 | 07:53 AM
EL Vap133's Avatar
All you need to know is right here:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
The reason people get upset when this is asked is because it is asked at least once everyday, this same question.
Old Feb 4, 2009 | 07:54 AM
TheRappist's Avatar
Trailing arms
Rotors
Calipers
pads
40/40 valve
new bushings
Wow, you just reposted my whole list! Very good, you can copy, but you forgot the master cylinder. Sigh.
Frank_ej6
Suspension & Brakes
Dec 23, 2014 05:59 PM
abadkevin
Suspension & Brakes
Nov 12, 2009 09:51 AM
EF9 JAMS!!!
Nov 24, 2005 03:13 PM
powerslide360
May 4, 2003 04:25 PM
Guam_CiviC619
Aug 17, 2002 06:34 PM
