tuning for bigger injectors
Old Feb 4, 2009 | 04:42 AM
trav39562's Avatar
Default tuning for bigger injectors
I am about to 450 ccs injectors in my 2000 civic ex and I dont have the money to take it to the shop for them to tune it. How or what do I do to tune for these bigger injectors. I have a cam,adj cam gear, edelbrock intake mani,k&n cold air, aem fuel rail,fpr, headers,exhaust, chipped p28 and msd 6 box and coil
Old Feb 4, 2009 | 04:50 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: tuning for bigger injectors
Even if you install a resistor box for the injectors (assuming they are low-impedance type), your car will bog out from overflooding. Your best bet is to save some money for a tune. An Apexi VAFC/SAFC will not do the job.
Old Feb 4, 2009 | 05:05 AM
trav39562's Avatar
i was just looking into an apexi vafc2. Are they a good investment. What all can they do. I am new to the piggy backs
Old Feb 4, 2009 | 05:31 AM
ddd4114's Avatar
Old Feb 4, 2009 | 05:38 AM
unusual71's Avatar
there is no easy way to do this.
either it is done right or it is unsafe, take your pick.
Old Feb 4, 2009 | 06:10 AM
b19coupe's Avatar
You don't need bigger injectors. Problem solved.
Old Feb 4, 2009 | 06:30 AM
Allurian's Avatar
x2 exactly with your set-up your arent going to benefit noticeablly from larger injectors. Put that money towards a swap or turbo.
trav39562's Avatar
well I left out that I am going turbo as soon as I can get some stronger rods and an oil kit for my turbo.
Old Feb 4, 2009 | 06:50 AM
b19coupe's Avatar
Install the injectors and have the car professionally tuned, when you install the turbo.
Old Feb 4, 2009 | 08:52 AM
NVturbo's Avatar
O.G. triple O.G.
Once you have a real EM system in your car, you will forget all about that VAFC2. I had a SAFC in my old setup and it was just there for looks (after tuning and Hondata S200 install) until I sold the damn thing on eBay.
Old Feb 4, 2009 | 09:04 AM
gsrhatch2356's Avatar
yes the vafc is a bunch of crap and only really good for screwing things up and changing the vtec engagment point. either way like already said, once you can get a real engine managment system then you can start to consider other options and if you really want to then get the s300 setup and a laptop cause they have a real simple formula for setting up for bigger injectors so all you have to do is select the size and up load it to the computer. Also with this you could start to play around a little with the tunning and get a wideband and research on the net and get help from the FI guys and learn how to tune yourself. even though I like a dyno tune better you can get a pretty good tune on the streets and then take it in to get it fine tuned.
b16bri
Sep 5, 2010 02:53 PM
sevenj
May 21, 2008 04:50 PM
Schister66
Apr 26, 2006 08:36 AM
Gfunk176
Jul 18, 2002 05:09 AM
