gsr engine wont start! help!
hey i have a 94 gsr and i swapped in a 98 gsr motor i switched the dizzy alternator and injectors to obd1 to fit my obd1 engine harness and everything plugged in perfect but when i switch my key in the iginition to 2 it doesnt show the check engine light which means my ecu is not getting any power im using a obd1 jdm p72 and its in perfect working condition does anyone know of any wiring or what could be wrong thats not letting power get to my ecu thanks.( fuel pump doesnt turn on either)
yeah i checked all the fuses under the head they are all good. and i checked the engine harness everything is good on that too. is there something that could be wrong with the wires under the dash like the ones that connect to the ecu or on the drivers side where the other fuse box is? im starting to get frustrated everything turns on abs,door open,srs, and battery its just the cel light that doesnt turn on.
nolicense526
Aug 25, 2008 05:05 AM
tougetuned_ef
Jun 13, 2006 05:39 PM
