New Guy with a couple questions
Old Feb 3, 2009 | 05:55 PM
Kricket88's Avatar
Default New Guy with a couple questions
Hello all, I'm Justin. I'm from Morganton, NC. I have a 88 crx si. Its got a b18a, Skunk 2 coilovers, heads been worked 5 angle valve job port polish and gasket matched, tri y header, short ram, full 2.5" exhuast, ctr pistons, arp rod bolts and head bolts and msd plug wires... i guess thats it? but anyways now to my question...
Ok the motor is obd0, I have an obd1 ls computer i think its a p75. I have a obd0 to obd1 jumper harness and i have an obd1 distributor. I was wondering if there was anything else i would need to go to obd1. If i goto obd1 will i have any check engine lights? Thanks for any help guys
P.S. I tried to use the search function but i just couldnt seem to find exactly what i needed.
Old Feb 3, 2009 | 06:10 PM
sgallagher's Avatar
Default Re: New Guy with a couple questions
You need a 4 wire O2 sensor also.
You should be good to go w/no check engine light.
Old Feb 3, 2009 | 06:31 PM
jhammond_82's Avatar
Reject Papi
sounds like quite the set up there.
Old Feb 4, 2009 | 04:02 AM
Kricket88's Avatar
sweet, thanks alot guys i tried to ask the same question on carolinahondas but they deleted my post? well whatever guess i found the honda site im going to be staying at. What about obd1 sensors I dont have like knock sensor? or will it not matter because they computer wont find one?
10psiLsEf2
Nov 11, 2011 07:36 PM
v8~killa
Mar 19, 2008 05:11 PM
DA9KING
Jul 2, 2007 03:25 PM
Loccster
Sep 17, 2004 04:09 PM
rice4life
Jul 25, 2002 01:59 PM
