EF-9 front end conversion question
sorry for the stupid question.. but what is the rad support?
I have the entire front bumper area... is the rad support where the hood latch is? or the little things that hold the rad nipples to the front of the car? they look a bit different from the USDM ones... i cant figure the rad support to be anything else... they are all spot welded to the frame. I am I just using the bumper cover, that metal lip on top of the bumper, bottom plastic lip, and the lights?
TIA
TIA
the rad support is the thing that's a part of the car...you don't need that. all you need is the hood latch support. just swith the jdm one with the one on your stock civic and you should be ok. the only things you'll need off the jdm front end are the hood, lights, that filler panel under the lights and between the bumper, the bumper itself, and the two metal supports that the bumper bolts onto. everything is bolt on really, and the wiring is self explanatory
QuestRacing-TypeR
Oct 3, 2002 05:33 PM
