Okay to use LS injectors on GSR motor? (searched)
Old Feb 3, 2009 | 10:47 AM
bettsbanger's Avatar
Default Okay to use LS injectors on GSR motor? (searched)
I was wondering if it is okay to use LS injectors and harness on GSR motor or if there is a difference in the injectors. the motor is obd2, everything is converted besides injectors.
Or should i buy the obd2 to obd1 injector conversion clips?
Wanted to consult HT before i hook it up.
Old Feb 3, 2009 | 11:18 AM
LS stretch's Avatar
Default Re: Okay to use LS injectors on GSR motor? (searched)
im almost 100% postive theyre the same size injector. ive used the injectors from all b series on all dif applications, stock setups and have never had a problem
Old Feb 3, 2009 | 11:20 AM
LS stretch's Avatar
wait i may have answered that wrong. if you have obd2 injectors you need obd2 clips, obd1 injectors need obd1 clips. you can wire on obd1 clips on a obd2 harness or vise versa, but you cant for example use obd1 clips on obd2 injectors
Old Feb 3, 2009 | 02:43 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i had the same question, and ended up using JDM OBD1 LS injectors on a g2 gsr (holy acronyms, batman!). they work just fine.
1988-91 Civic si/crx si Peak and hold 240cc
1992-95 Civic si/ex Saturated 240cc
1996-00 Civic Saturated 240cc
1990-91 Integra Peak and hold 240cc
1992-00 Integra ls/gsr/type R Saturated 240cc
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 280cc
Old Feb 4, 2009 | 11:12 AM
Thanks for the input, ill give it a try. I figured for the most part it should work fine.
thaiphob
Aug 4, 2017 10:40 AM
gsrcivic1992
Mar 14, 2005 06:48 AM
ekb18cCivic
Nov 15, 2003 05:12 PM
GreenD
Apr 3, 2002 10:02 AM
94cxHybrid
Aug 29, 2001 11:27 AM
