itr header what cat?
Old Feb 3, 2009 | 09:28 AM
blackhbkid's Avatar
Default itr header what cat?
Ok so like the title says.
I have a 1995 gsr with itr 4-1 header i would like to use a high flow cat or test pipe but which one will i use? Am i better off just getting a test pipe made?
Old Feb 7, 2009 | 09:33 AM
roc's Avatar
roc
Default Re: itr header what cat?
replace your cat with a test pipe,that should work
Old Feb 7, 2009 | 09:44 PM
JDM JON's Avatar
i recommend the password JDM adj. test pipe....or the omni power adj. testpipe...
is an investment in itself....works with any US or J-spec header with 2.5 collectors....
you can't go wrong....
just make sure you dont go through inpsection station with it on...
lilbinky
May 16, 2011 10:29 AM
slateEKsi
Jul 26, 2010 04:06 PM
type-GGSR
Mar 4, 2008 09:25 PM
SirEm1
Oct 6, 2004 11:57 AM
