B16A Running Rich (Fuel Curve?)
Timing is at 14
Ignition components has been changed (plugs, wire, distributer, MSD)
o2's changed
Injectors running fine
fuel filter is replaced
Used fuel system cleaner (Penzoil)
I even have the Fields vtec AFC, but my car is still running rich. My settings right now are:
-4@1k
-4@2k
-3@3k
0@4k
+2@5k
+2@6k
+2@7k
0@8k
vtec engagement is at 4400. I understand that there is a diff between a close loop and open loop circuit, but the AFC should be changing both maps at narrow and wide band no?
Are there any other areas I should check? And if anyone has the same ECU piggyback for the b16a, what are ur settings? I talked to a few ppl in my city and it seems as though they all have a problem wirht running rich as well.
o2's changed
-4@1k
-4@2k
-3@3k
0@4k
+2@5k
+2@6k
+2@7k
0@8k
dj_seloe
Oct 15, 2003 07:32 PM
