Exhaust and Sway Bar question
I did a search and did not find the answer(s) to my question(s).
I have a 97 LX sedan and installed ST front and rear sway bars and a Apexi WS exhaust. My issue is the piping before the muffler is pretty low. In fact on occasion the piping will scrape on the ground when the car is full with passengers.
1) Has anyone else have this problem?
2) If you did, what did you do to resolve ths problem?
a) Custom piping? (Pics would be helpful)
b) Remove rear ST sway bar and install OEM
front sway bar?
The reason for my post is, I would like to replace my ST springs and Tokico blues for a coil over set-up, so I can lower my LX even more.
Thanks in advance for all replies.
Brandon
front sway bar?
Brandon
front sway bar?
Brandon
front sway bar?
Brandon
They conform to the floor quite well.
P
Thanks,
Brandon
Thanks for your replies. I did not replace the exhaust hangers and did not notice if they were bad. The one thing I just thought of is, does Apexi make different versions of the WS exhaust based on whether there is a rear sway bar or not? Because the one I ordered is/was for an LX model which does not have an OEM sway bar. I had forgotten I had an ST sway bar installed before I purchased the Apexi WS exhaust.
Thanks,
Brandon
Thanks,
Brandon
All DX,LX,EX,SE and Value Pack / with/without swaybars.
Refer:
http://www.erzperformance.com/product_p/116-KH07.htm
P
Nope, One size fits all
Refer:
P
Refer:
P
Thanks,
Brandon
NeKe1point0
Aug 10, 2008 02:25 PM
CrxUnderConstruction
Jul 17, 2004 08:05 AM
hondacivic4g
Dec 17, 2003 09:28 PM
