Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Wheel questions
Old Feb 2, 2009 | 04:24 PM
JackSparrow's Avatar
Default Wheel questions
What size are the factory 2008 16" alloy wheels?
16x7 or 16x6.5?
Backspace at 42mm?
What's the hub bore size?
I believe the bolt pattern is 5 x 114 mm...
I was wondering if it'd be worth it to buy some ligher-weight wheels, maybe forged aluminum for use in summer, and sell my factory 16" alloys.
I believe the factory alloys weigh about 19 lbs and I've seen several wheels at 16x7 and 5x114 that are between 12-15 lbs.
I would like lighter wheels for both improved ride quality and a slight power "increase." I found a site that does horsepower calculations and figured out that dropping 5 lbs of wheel & tire could feel like either adding 5 hp to the r18 motor (?) or dropping 80 lbs of sprung weight.
The factory rims look very nice, but I don't like how "portly" they are.
Old Feb 2, 2009 | 04:57 PM
pd0019's Avatar
Default Re: Wheel questions
16x6.5 +42 i believe. hub bore is 64.1. bolt pattern is 5x114.
look into 17's too. going to a lighter wheel is always a good idea. my personal favorite are rpf1's but there are a lot of choices. picking out a good tire is also important too.
your "power increase" is off. you will notice a "power increase" but not by that much. it is more like 10lbs to every 1hp.
Old Feb 2, 2009 | 09:17 PM
Thanks.
For the moment, I prefer the idea of 16's for slightly less weight and typically narrower footprint (205R/55 vs. 215R/45) for the "underpowered" R18. However, I was stunned when I bought 195/65R-15's for snow tires that there was a dramatic difference in sidewall flex, and the 15's felt almost twice as "squishy." Is there also a huge difference between the handling (flex) of 215/45R-17's vs. 205/55R-16's?
A little off topic, but half the reason I'd like to do this is for the minor power & economy increase. But I was wondering would a cold-air kit make more difference power-wise than the lighter wheels, at half the price or less? My scan gauge II shows that the inlet temp from the factory is usually only 15 F warmer than ambient at cruise, so for a cold air kit to make more power, the main perk should be more airflow rather than just cooler air.
Old Feb 2, 2009 | 10:39 PM
pd0019's Avatar
sorry...honestly dont know how to answer your tire question.
i dont think intakes do much (i have one). i got a really good price for it that is the only reason i have it. i personally have always felt more of a difference with lighter rims than with an intake.
Old Feb 3, 2009 | 05:14 AM
No problem, just curious if you or someone else had gone from 16" to 17" rims with the stock tire size and noticed a difference. (I suppose I could go test-drive an Si and I could probably find most of the difference, besides the Si's 20% increase in spring rate)
So you've bought lighter wheels?
How much lighter were they than what you had before?
Sean @ ESG
Nov 26, 2008 07:32 PM
huge230
Apr 28, 2007 06:52 PM
dayaftertomorrow33
Feb 5, 2007 04:27 PM
TypeR 01 886
Oct 23, 2003 06:32 PM
davidh_125
Mar 10, 2003 06:22 PM
