my first ever mod ... finally ..
I found a summer job and finally raised some money ...
i borrow this pic from someone else, sorry ...
went to the junkyard today looking for misc. stuff ...
I came across this set of rims from a 88 CRX in the corner, I ended up paying 140CAD (roughly 90US) for them ...
they are in ok condition, some scratch and marks, but nothing major.
tomorrow i should able to get some azenis mounted on there...
Also ..
when I was at the junkyard, I asked one of the guys there, if 195 60 14 will fit.
since i know these are 14x5 rather the recommend 14x5.5 for 195 60 14.
but he said it will fit and told me to look at his prelude (older gen.) for prove, i went outside and look, it fits, that's why i brought it.
i am just wondering if it is safe though ?
and yeah .. back to my question ..
will 195 60 14 works on 14x5 ?
[Modified by BAR-F1, 1:24 PM 8/8/2002]
[Modified by BAR-F1, 1:28 PM 8/8/2002]
it might be able to work but more importantly u'll wanna figure out your overall diameter and see if you can keep it close to stock, unless you don't mind throwing your speedo and odometer off a little.
theres been post about tires almost everyday since ive been a member..next time pay attention..yeah, they ll fit just fine..just expect the speedo to be off a little
i know i know ...
i just need someone to tell me 195/60-14 will work on a 14x5 ...
why would 195/55 be a better size .. it will throw off the speedo even more...
195/60 have only 1.1% error ...
I only need someone have experience to tell me it will fit, dont treat me like a newbie ...
qoute
"i know i know ..." Well if you know why are you asking again?
"i just need someone to tell me 195/60-14 will work on a 14x5 ..." Four people already did
"why would 195/55 be a better size .. it will throw off the speedo even more...
195/60 have only 1.1% error " because they come with 185/60/14's so... by increasing the width (185mm to 195mm) you must decrease the Ratio of sidewall 60-->55
"I only need someone have experience to tell me it will fit, dont treat me like a newbie ..." Don't title your post "my first ever mod" if you don't want to be treated like a newbie (anyone who's already done 1 mod is already more experienced than you). and it also might help to ask intelligent Q's.
the answer is... Yes the tires the guy said(195/60/14) will fit will fit so will the 185/55/14's that the gut on the board suggested
[QUOTE]i know i know ...
195/60 have only 1.1% error ...[QUOTE]
Well 195/55 is just alittle shorter than a 195/60/14
I had 195/55 on mine and the speedo was just about exactly right. How did you come up with that 1.1% off on the speedo. Do you know the formula for Tire equations. the numbers stand for approx. 195mm x 60% of the with is the Aspect ratio for the sidewall height x 14in rims.
[Modified by 98EK4, 1:08 PM 8/8/2002]
That is one nice CR-X you have there, they are hard to find in that good of body condition anymore, unless, of course the driver side door is yellow.
maybe i am not clear ...
i have a 98 civic sedan
it is 185/65-14 ...
for god sake ... stop talking to me like i dont know **** .. it is pissing me off ...
today i went out and buy the tires .. the mounting guy said it is a tight fit and it will be hard, however he did able to mount them on ..
[Modified by BAR-F1, 4:01 AM 8/9/2002]
it is 185/65-14 ...
qoute
i know because i"ve been on the board for over an year, i search but with no results, i need to make sure before i buy the tires, so i wont waste 450CAD into buying perfectly good tires that i cant used ?
i said i want someone with experience tell me to, being a stiffer sidewall it might not able to get inside the rim, and the sidewall might not track straight due to less support, i want it to be safe.
like i said .. my civic came with 185/65-14, so therefore using 195/60-14 will get me a 1.1% error, and by using 195/55-14, it will get me 4.4%.
which is better ? 1.1% or 4.4% error ?
IT IS my first ever mod, i dont have spare money to throw around so i am extra catious to make sure i dont make a mistake, like buying something that wont work. and knowledge toward cars doesn't not exactly mean how many mod you have done to your own car.
A man can have no knowledge at all and walk into a shop and come out having a very fast car only because he have $$$
i hate ignorant people like you, basing my intelligent on the mod i have done to my car.
i dont even get this sentence ...
[Modified by BAR-F1, 4:12 AM 8/9/2002]
[Modified by BAR-F1, 4:17 AM 8/9/2002]
since we're on the subject,
how to tires throw your speedo out of wack.
If you get bigger wall tires than the speedo goes a bit off.
But what if you go lower wall on the tires, than what, does the speedo still go off ?
Congrats on your first mod ever! :-D
