brake line fitting question
i am removing the abs from my 95 integra. i am planning on making all new hardlines for under the hood, and was just wondering if i could re-use all the factory fittings on the new lines, or if i should get all new fittings? thanks
As long as there's no corrosion or obvious signs of damage, I don't see why you couldn't reuse them. Another thing to keep in mind is they're probably not very expensive, so it might be worth your while to just replace them.
da1lydr1ver
Dec 15, 2007 10:50 PM
