Leaking brake fluid =[
Old Feb 1, 2009 | 05:00 PM
Dark_Templar's Avatar
Default Leaking brake fluid =[
So just the other day i was driving and all of a sudden my brake light went off but my E-Brake wasnt deployed and i could feel my brake gradually start sinking and i checked my brake fluid and it was almost all empty, so i added more and bled my brake lines and it worked for about 5 hours and the light went off again.
It kept going on and off for about 10 minutes then went completly solid.
Check my lines and they werent leaking.
any ideas on what i can do stop the leaking?
It might be my master cylinder im thinking?
Old Feb 1, 2009 | 05:17 PM
P_Adams's Avatar
Default Re: Leaking brake fluid =[
I would check the entire system for leaks but 18 of 20 times it's the Brake Master Cylinder. It corrodes from the inside from water ladened brake fluid and renders the machined piston bore useless. It will require replacement if everything else checks out.
P
Old Feb 1, 2009 | 05:42 PM
P
thanks for the reply.
Have any idea how much for the master cylinder on a 99 accord J30A1?
Old Feb 1, 2009 | 06:54 PM
P_Adams's Avatar
TAS Automotive
http://www.tasauto.com/Product/Browse.aspx?d=1100&p=1
$109.00 Genuine Honda OEM V6
Parts Geek (Adler)
http://www.partsgeek.com/catalog/1999/honda/accord/brake/brake_master_cylinder.html
$99.00 Aftermarket
Saccucci Honda
http://www.hondapartsdeals.com/hpa_parts_list.php?vin=&Label%5BProductID%5D=ACCOR D&Label%5BYearID%5D=1999&Label%5BDoorID%5D=4&Label %5BGradeID%5D=LXV6&Label%5BAreaID%5D=KA&Label%5BTr ansmissionID%5D=4AT&Label%5BSectionID%5D=CHASSIS&L abel%5BIllustrationGroupID%5D=MASTER+POWER+%281%29 &ProductID=5&YearID=17&DoorID=4&GradeID=48&AreaID= 2&TransmissionID=5&SectionID=6&IllustrationGroupID =3278
$104.00 Genuine Honda OEM
P
Old Feb 4, 2009 | 05:30 AM
lunarone's Avatar
P
To inquiry on what P said ---
Does that lead to the leak that is seen when brake fluid is in between the booster and master cylinder?
Old Feb 4, 2009 | 06:00 AM
dleccord's Avatar
Don't buy the master cylinders from Autozone.
I've replaced 3 within a year from them for my '92 Mustang.
Don't get the refurbished ones.
Old Feb 4, 2009 | 06:28 AM
TheMuffinMan's Avatar
He knows where you live!
^ Lifetime warranty + half the cost + rebuilt OEM Nissin?
I'll take it
Old Feb 4, 2009 | 08:03 AM
dleccord's Avatar
^I'll take you home tonight.
Old Feb 4, 2009 | 10:38 AM
P_Adams's Avatar
Short answer: YES
The fluid is making it's way past the Piston / Cylinder Bore seal and making it's way out past the Pushrod Seal.
In really bad cases, the Brake Fluid sometimes makes it's way into the brake booster; attacking the Vacuum Diaphram.
P
adamcm16
Apr 10, 2014 05:07 PM
businessmanph
Feb 9, 2006 07:32 PM
Tench
May 11, 2004 10:23 AM
Hatchd
Jul 28, 2003 08:43 AM
94BlackRS
Nov 28, 2002 02:43 PM
