Misc B/D series parts. Wideband/Clutch/Flywheel/Romulator
B series XTD 6 puck sprung hub clutch with 8lb flywheel. These are excellent units VERY similar in quality to the Action clutches. I have used many of these clutches from boosted D/B series to stock applications and all motor DD. They offer smooth engagement (for a puck) and very good durability. Never had a single issue with these clutches. The combo here has approx 3k miles on it. PLENTY of meat/life left. Paid $240 + shipping for the combo new. Asking $180 for both!
B series shift linkage. Complete with shifter and Energy Suspension poly bushings (Black). Works perfectly, not bent. Asking $80.
Stock D16Y8 camshaft and timing gear with cam seal. Not rusted or anything like that. Excellent shape. $40
99 Civic SI alternator. Tested, works perfectly. $50
99-00 Civic SI muffler. Was modified to fit on EK hatch with 2.5" exhaust. Can be made to fit either hatch or coupe with some work. $20
2 D Series differentials. One has a bad ring gear. Make me an offer on either one
1 Stock B16 differential with ring gear. Good working condition, $40.
SRR 4.75 final drive for D series transmissions. Works great for all motor, I am boosted so I swapped it back to the stock diff. Sells new for $480 retail. Cheapest I have seen these things was $350 on a group buy. $100 takes it off my hands!
GSR +OUTTER+ transmission housing case. Someone painted it red, other then that its in excellent shape. Not broken/cracked. etc. $50.
4 PM7 JDM DOHC ZC pistons. Used, obviously, but in good working order. They do not have the pins, reuse your old ones. Excellent for higher compression all motor D series build ups, especially at this price! $50
Civic Type R Stock B pipe. Dual resonators, larger diameter piping then the USDM models (Even the 99-00 SI) and its fully stainless steel! Will accomate the larger 2.5" JDM cats also! This system is unmodified, as it sits it WILL NOT bolt up to any USDM model car that I am aware of due to the length of pipe. It will fit EK models with no trouble as far as the pipe hangers. You will need to shorten the from pipe for it to work with USDM cats or get a JDM cat/test pipe to make it a complete "bolt up" unit. I ran it with a test pipe on my EK hatch, worked fine. Did 197whp with this same pipe! Paid $350 for the complete exhaust including the muffler. Asking only $50 for the B pipe!
Complete 1996 OBD2 Integra LS B18B1 head. Has the cams, cam caps, valvetrain, valvecover and even the intake manifold. Complete minus the dist! $50!!!
3 B series flywheels. All the same weight according to my scale. Good shape. $20 each.
LOTS of Misc engine mounts. Let me know what you need along with an offer, I prolly have it!
1996 D16Y8 shortblock. Complete, even had the headbolts to go with it! Has spun #4 main bearing. Good for parts or fixing. $50 for the whole deal!
Homemade DIY wideband. Uses the Honda 5 wire O2 sensors found in the Civic VX/HX models. Very accurate device! I used this for a while to tune with using Crome. Worked flawlessly. I have since got an Innovative wideband which has the built in display. I no longer need the DIY unit. Tested, works fine. Comes with the 5 wire. Input the voltage out back into the O2 signal side of the ECU and datalog with it and you can accurately tune your own car for cheap! Everything you need for $80. The sensor alone is worth this amount and then some!
Almost brand new B series hydro starter. I bought this about 1 month before I parted out my GSR swap! This thing has hardly any usage at all on it. Paid $130 brand new, will let this go for $80!!
Misc TPS/MAP/IACVs. Everything tested, known good. 3 larger style IACV for GSR manifolds and 3 of the smaller B/D series style. Make me an offer.
Transtronics romulator. Used for Hondata/Crome real time rom emulation. Works perfectly, no problems. Paid $180 new, asking $80 used.
Greddy EGT gauge. Gauge only, no sensor or wiring. Face has some wear, nothing that makes it non visable. Asking $20 for the gauge.
I have pictures of everything. If you don't see it here, ask. I will email you pictures asap!
neutron91
Jul 18, 2007 04:22 PM
