FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
Old Feb 1, 2009 | 02:28 PM
hotrod0001's Avatar
Icon3 FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
92-93 tails with brand new OEM gaskets--$50 plus shipping
SOLD!!!!
LS/Vtec only 7000miles
B18A bottom, B16 head
rebuilt top to bottom
New honda bearings, seals and gaskets thoughout
LS rods with ARP rod bolts...PR-3 pistons
P72 oil pump
b16 water pump
Gates timing belt
OBD-1 GSR distributor with new cap and rotor, NGK wires and plugs
hondata intake gasket with extended intake studs
B16 intake manifold with LS throttle body
type-r valvesprings and retainers (b16 cams)
ARP headstuds
cometic headgasket(.045) 11.3to1 c/r
full-race LS/V kit (oil line, fittings and dowel pins)
Toda flywheel(resurfaced) with a comp stage 2 clutch(only 7000miles)
stock LS tranny (miles unknown, 2nd gear stratches if high revved)
Have most of the reciepts for the build
$1700 for everything!!!motor,tranny,Driveshaft shop stage 0 axles, innovative full motor mount kit and ecu PO6 (i believe) chipped with stock b16 map
Brand new 90-93 mishimoto radiator still sealed in the bag...also have 2 used 12" slim fans with brand new mishimoto mounting straps
SOLD!!!!
PasswordJDM one piece rear strut bar (made for an EF modified to fit a DA)
SOLD!!!!
Benen rear lower one piece tie bar 90-93 integra
SOLD!!
Old Feb 3, 2009 | 03:08 PM
hotrod0001's Avatar
Default Re: FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
Bump!!! New Price on the motor!!
Old Feb 7, 2009 | 09:56 AM
hotrod0001's Avatar
Bump!! updated prices!!
Old Feb 17, 2009 | 09:06 PM
hotrod0001's Avatar
Bump
hotrod0001
Northern California (Sales)
Feb 25, 2009 08:24 PM
KMk51188
Jun 11, 2006 05:46 AM
HYBRID FREAK
29
Apr 5, 2006 03:06 AM
untitled
Jul 13, 2003 08:41 AM
