Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Question about drive by wire.
Old Feb 1, 2009 | 09:01 AM
irollerblade's Avatar
Default Question about drive by wire.
I was looking at purchasing a new Si and the one I test drove had Like a full second response from when I hit the gas till the car actually moved, it was really noticeable are they all like that?
Old Feb 1, 2009 | 09:14 AM
i-VTEC_DOHC's Avatar
Default Re: Question about drive by wire.
mine its pretty much dead on with reaction time.
the only time it lags is when the clutch isnt fully engaged which is the hill assist feature.
Old Feb 1, 2009 | 09:24 AM
Idk why this one was doing this then. I was just like uhhh whats going on haha.
Old Feb 1, 2009 | 09:39 AM
my car was like that when i first got it.
it was fine after a few days after the ecu adjusted to the climate and elevation change
Old Feb 1, 2009 | 11:26 AM
vladd's Avatar
a full second is pretty bad. i have a delay in mine too but it's a split second, not too noticeable.
Old Feb 1, 2009 | 12:46 PM
SImadness's Avatar
hill assist feature?
Old Feb 1, 2009 | 12:56 PM
203_EM2's Avatar
I never noticed a difference in mine between My Mugen and my old em2
Old Feb 1, 2009 | 07:17 PM
Yeah I drove my friend's Si and did not notice anything, I'm guessing the car might not be running right.
Old Feb 1, 2009 | 08:28 PM
ajpturbopittsburgh's Avatar
Wait. I don't think the Si has a hill assist feature? And you wouldn't want lag on the throttle when you are sitting on a hill. If you did you would drift back even further waiting for throttle to come on. A car with hill assist uses brakes to hold the car in place while you engage the clutch
Old Feb 1, 2009 | 08:30 PM
vladd's Avatar
the em2's have a cable throttle, don't they? you really can't notice the difference between cable and electronic?
Old Feb 2, 2009 | 10:29 AM
07FG2's Avatar
Why is it called 'drive by wire' when its electronic?
Old Feb 2, 2009 | 11:07 AM
vladd's Avatar
because you have electronic wires between the pedal and throttle body instead of a cable.
Old Feb 2, 2009 | 02:45 PM
thesmogman's Avatar
I just took my update class for smog and they now call it "ETC" or Electric Throttle Control.
This system does have some learning to do, as it does take a bit to adjust to the drivers demands. It will get use to what the driver does as long as he does it normally all the time.
This system does have other features like: Guessing what the driver is going to do and adjust for it before the driver does it. It is suppose to help emissions by pre-planning what to do if....... then I will do this. You get my point.
Another thing it will do is provide feedback to the pedal too. Just in case you feel something moving your foot.
What will be next?
Old Feb 2, 2009 | 05:09 PM
24boosted's Avatar
Shift into the wrong gear and you will have delays.
I have two gauges, digital boost/vac and electronic boost/vac gauge in my Si, absolutely no hesitation. Gauges are registering instantaneously with pressure on the gas pedal. If there were any lag with the DBW or ETC as mogman pointed out, the gauges would be slow to react as well.
Old Feb 2, 2009 | 05:25 PM
dirtySOHC's's Avatar
What will be next?
really good info....i had no idea it took time for the system to get into a "rhythm" with the driver.
Old Feb 2, 2009 | 05:48 PM
07FG2's Avatar
What will be next?
Man sounds like my car is going to get smarter than me and become a TRANSFORMER!!! also reminds me of that irobot movie
Does it have to relearn every time you start the car up? Or does it have like a memory bank? If someone borrows my car for the day, will it adjust and learn that quickly?
Old Feb 2, 2009 | 08:39 PM
24boosted's Avatar
This has been known for some time, even with some prior Honda ECUs. Why piggy back tuning systems don't do so well. The ECU learns to readjust against the piggy back as well as adjusting to driving conditions. Disconnect the battery for a few minutes usually resets the memory. Do a search, even older Hondas had "learning" ECUs.
Zack...
Jan 6, 2011 09:47 PM
instructor74
18
Apr 12, 2009 06:03 PM
cmdr430
22
Nov 20, 2007 06:55 PM
ECX
Oct 29, 2007 07:26 PM
yobbr5
May 24, 2007 09:38 AM
