EGR Valve Lift Insufficient Detected?
Ok i got my CEL cleared and that was the code that was detected. Do i need to worry about it? If it pops up again how should i fix it?
Thanks in advance.
Thanks in advance.
Sounds like there may be some carbon build up in the EGR valve, try removing it then cleaning it with brake cleaners. I also have one for sale if that one is malfunctioning/dead.
my wife has a 98 accord lx 4cylinder and she has had that code for like 2 years now, we replaced the egr valve and it came back, we may have to take out the entire intake manifold to clean all that carbon build up, for you: i would say run seafoam through your brake booster vacuum line and clean the egr valve ports, but it not that big of a deal, at least for a accord
those engines are no joke man, i did an entire can of seafoam, cleaned the egr ports like 5 times, did lucal fuel injector cleaner, basically did everything basic, and the light still does not go off, i have a friend with the same car and he had to take out the intake mani and scrape all that carbon build up, then his went off, i guess thats what ill have to do, but it does have 175k and i dont think the previous owners took very good car of the engine
Doug Winsor
Aug 26, 2015 12:40 PM
hollywood28601
Dec 27, 2010 11:09 AM
