ERL superdeck 2 block or golden eagle block
Old Feb 1, 2009 | 01:59 AM
takata_nsxr's Avatar
Icon7 ERL superdeck 2 block or golden eagle block
just want some info from some of you guys that used erl or ge blocks...erl is more expensive than golden eagle but golden eagle has been around longer....what should i go with ......thanks
Old Feb 1, 2009 | 04:07 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: ERL superdeck 2 block or golden eagle block
i have always used golden eagle. they have bever let me down
Old Feb 1, 2009 | 04:21 AM
DaveF's Avatar
Golden Eagle all the way ! we have been using them for damn near 10 years now and they take everything we throw at them.
a friend of mine owns an erl block, and has had nothing but problems with it...... i told him long ago....should went Golden Eagle, but he didnt listen and now hes got prob's....
Old Feb 1, 2009 | 05:27 AM
boostedcivicsir's Avatar
Mr. Badwrench
this is one of those threads where people are gonna tell you both.
im on my third year with my erl superdeck, joe simpson is on the 4th season with his also.
i have a friend that did have a sink problem with his erl, but they made good on it.
Old Feb 1, 2009 | 07:02 AM
locash's Avatar
I've got an ERL B-series motor in my race car, and a worthless ERL K-series motor, as they built it out of an 08 Accord block, and nothing bolts up to it. I told my ERL dealer that I was going to be sending in a CRV or TSX block, and ERL must have gotten a good deal on these brand new 08 Accord blocks, so they used that instead. The head gasket was the first difference, had to get golden eagle to make us 88mm gaskets out of stock Accord ones. After that, the standard k-series head bolts were over an inch too short. Then, the custom s2000 oil pump kit that they sold me with the motor didnt bolt up. Apparently, they did this to multiple people, and when I called and mentioned that the head bolts didn't fit, they gladly took my order for custom head bolts, without telling me that I was going to run into a lot more problems than the headgasket being different, even though I asked if anything else would be different. My buddy Manny was having the exact same problems, and now neither of us have usable motors. I've been told to send the thing back and they will build me another motor, but I've been so frustrated with it that I just put a plastic engine bag over it and left it in a corner of the shop. I'll be sending it back to ERL shortly, but hopefully it doesnt take as long to get back as it seems to for everyone else that has had to send a motor back to ERL.
Short story is, I'm pissed that they knew about the problem, (I had this worthless block for almost a year, still in the ERL crate) but instead of telling me on my first problem call, they just let me keep going, wasting more time and money.
I hope that I don't have more problems once it goes back to them. This week, I'll be tuning the B-series ERL motor I have, and I'll hope for no problems..
Old Feb 1, 2009 | 07:21 AM
rota92
Guest
Posts: n/a
Golden Eagle all the way, great bunch of people to work with and a killer product
Old Feb 1, 2009 | 08:52 AM
Boner_Ben's Avatar
I dont know anyone that has had problems with a GE block so that gets my vote 2 seasons on mine and no issues, no headgasket failures.
Old Feb 1, 2009 | 10:26 AM
Icon7 Re: ERL superdeck 2 block or golden eagle block
thanks guys....i just asked because i was recommended from a local shop to do the erl block because of there superdecks 2 extra support on the block
Old Feb 1, 2009 | 10:30 AM
ninesecrx's Avatar
OUCH...that sounds terrible!
Old Feb 1, 2009 | 10:34 AM
sgnlab's Avatar
If I only had these two to choose from GE. But consider Benson's hit up Mike Laskey. I have nevr had a problem with my block 100% happy.
Old Feb 1, 2009 | 10:35 AM
Robs_B18c's Avatar
I like my GE Block. FTW
Old Feb 1, 2009 | 10:37 AM
reaction360's Avatar
I've had my GE block for over 4 years now. on its 3rd build. I blew the **** out of the motor (broke a valve) and destroyed everything. Only thing salvagable was the block n sleeves. bored it and rebuilt it and made over 700whp no problem.
Old Feb 1, 2009 | 10:50 AM
b20vtek's Avatar
have my GE for over 2 years now never had a problem
Old Feb 2, 2009 | 09:16 AM
CerealKiller's Avatar
You do realize that GE's HD sleeves are braced, so If you're looking for "extra support" the only choice would be GE, about 2 inch down of braced sleeve FTW.
Old Feb 2, 2009 | 09:31 AM
nos51's Avatar
well my buddy just put in his brand new golden eagle block in his car the other night and first of all the car started mixing coolant,had been idling for only about 15-20 minutes,looked under the oil cap and found milk shake.car also has a coolant leak.to make a long story short,there are micro cracks on the back of the block leaking coolant.took the head off pour water in between the sleeves and it comes back out through the back of the block like sweat coming out of you pours only way to explain it.its obvoius the block was damaged somewhere in the sleeving process.he calls robert at g.e. and roberts tells him that its nothing they could have done wrong b.s.mind this is the second block he has problem with from g.e. sleeves sunk on the 1st one.i personally know peole that run g.e. blocks and have had no problems and i would have used them for my build but now this makes me think twice.i hope they do the right thing and take care of this one because the last one ended up being a paper wieght.
Old Feb 2, 2009 | 10:34 AM
K-Serious's Avatar
Did you have any problems with the b series ERL block?
Old Feb 2, 2009 | 10:56 AM
BLKTeg94's Avatar
Golden Eagle has REALLY stepped up their game the past couple of years! It's been a LONG time since I've heard or read on here about one of their sleeves sinking or failure! GE gets my votes hands down! Wouldn't recommend anyone else!
Old Feb 2, 2009 | 11:00 AM
JDogg's Avatar
we have had alot of problems with erl blocks.
sunk sleeves, 8 month turn around time (to get a block w/sunk sleeves fixed), crappy hone, crappy deck, crooked line hone.. etc.
Old Feb 2, 2009 | 12:50 PM
ninesecrx's Avatar
Double ouch!!
Old Feb 2, 2009 | 01:00 PM
ShawnR's Avatar
jw why those 2 companys? ever thought about going to miller (NRGTECH) he does great work also!!
Old Feb 2, 2009 | 01:16 PM
Turbo-charged's Avatar
ive had the same ERL block in my car for 4 years.
boostfeen's Avatar
..AEBS! ...Once a block comes back from sleeving, Miller does everything else.
Old Feb 2, 2009 | 10:23 PM
locash's Avatar
Just fired it up Saturday, I should have it on the dyno by the end of the week, and we'll see how it goes then.. I'm hoping for the best..
Old Feb 3, 2009 | 10:23 AM
wanna see what she makes
Old Feb 3, 2009 | 02:20 PM
jdm inc's Avatar
Golden Eagle FTW.
