Brake Light Always On
Old Feb 1, 2009 | 12:13 AM
bandit080000's Avatar
Default Brake Light Always On
Hey everyone,
So I just got back from a work trip and left my car in the remote lot for 8 days. So I got back in the car and now the brake light doesn't turn off when I drop the parking brake. I'm guessing there's a sensor that controls the light.
Does anyone know how this light is controlled? And is it possible to replace just the sensor or whatever controls the light?
Thanks!
Old Feb 1, 2009 | 12:29 AM
BlueIntegraBoy's Avatar
Default Re: Brake Light Always On
Fill the brake fluid reservoir with brake fluid
Old Feb 1, 2009 | 01:04 AM
The reservoir is at the max line. Does the cap contain a sensor that illuminates the indicator based on how full it is?
Old Feb 1, 2009 | 02:43 AM
stiffinEK's Avatar
check your brake pads, and if you got abs. do you feel a difference within the wheels not locking?
other than that, brake reservoir needs fluid and plus, that cap rarely goes wrong.
and also, one of the uncommon thing to look at, check your brake lights. press the brake and have someone see if your brake lights turn on. if it does not turn on, it can be your brake switch on the brake pedal. i know alot of old BMWs got that problem.
Old Feb 1, 2009 | 03:11 AM
concept's Avatar
subnet-mask
check the spring on your break assembly, the light will be on if it's loose.
Old Feb 1, 2009 | 05:16 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Attach to your brake pedal there is this little nub either blue or black and that thing pushes against a " button switch" and when you step on ur brakes, the thing Depresses/releasing the button and it activates ur brake lights, they tend to break into pieces it happen to me..couple of bucks at the dealer.
Old Feb 1, 2009 | 05:45 AM
bossm's Avatar
i have the same problem in my em1 and the brakes started squelling so i replaced the pads and the brake light went right off and still has never turned back on
Manmeetsingh
May 20, 2014 08:06 PM
sonson6
Apr 8, 2007 05:58 PM
white99accordEX
Dec 22, 2005 04:08 AM
Pullig
Aug 30, 2005 11:51 AM
94BlackRS
Nov 28, 2002 02:43 PM
