Wheel Locks????
i'm about to get a set of Honda wheel locks for my civic that has gsr rims. Are these worth getting? i'm getting them for 35 bux at a discount rate. Or are these something most thieves easlily get around? thanx, i need fast replys cuz i'm getting them tomrrow if they are worth it.
locks or no locks..if the theives *********** want ur wheels bad enough, they ll have them off inside 5 min s..
WTF !!! they can have ur whole car in less that time
[Modified by deepnite, 7:47 AM 8/8/2002]
Waste IMO. I agree above with if theives want them, they get them. I have a lock set, but don't even bother. I swap rims so much, its just a hassel.
i think 35 is the same price as the mcgards and the hondas are the exact same as the mcgards so...
However, they are not EXACTLY the same as the OEM McGards. These non-OEM locks are a little on the long side and stick out a little too much. In addition, the key on the non-OEM version comes in a 21mm size which is different than the OEM 19mm lugnut size, so you can't use the stock lug wrench with them.
The McGards OEM locks have a triple nickel-chromed finish. Compared to the non-OEM ones, they are shorter and fit semi-flush with the wheels. They also have a smoother bevel to fit nicely with the wheels. The OEM locks will also be covered under Honda's warranty. And finally the key is the same 19mm size as the stock lug nuts.
For only a little bit more, you can get the better fitting OEM wheel locks. They are definitely worth it!
GS-R wheels are very popular with thieves!!!
