rim fitting
Old Jan 31, 2009 | 09:50 PM
civic59's Avatar
Default rim fitting
just a small question. ive been doing research and i just wanted to make sure that this certain rim will fit on the a 94 accord.
the rim is a katana destiny
17x7 205/50 + 40
and the bold pattern is 4 lug universal.
heres a picture with out the center caps. i had this on a 2001 civic and the lug pattern was 4x100 so im just wondering if this rim can fit on a 94 accord.
Old Feb 1, 2009 | 05:03 AM
P_Adams's Avatar
Default Re: rim fitting
17x7 205/50 + 40
Well, not quite universal....
For the Accord you will need a 4x114.3mm bolt pattern. You have a dual pattern wheel set. Hopefully the other bolt pattern is the correct one.
On dual pattern sets, the 4x100 and the 4x114.3 are often paired together. Do a Google! search for your set; you should get your answer there.
P
ndiehm
Apr 23, 2012 11:20 AM
94_Acorn
Mar 19, 2009 07:09 PM
tArebelpinoy
Oct 1, 2008 08:04 AM
vanilla gorilla
Jun 3, 2008 07:33 PM
tfalconier
Jan 19, 2004 05:36 PM
