Mini-Me Swap, Timing Belt Kit Compatibility???
I just picked up a Z6 head for my d15b7 daily driver civic coupe. I know all the parts i need for my swap but im not sure on the compatibility of a timing belt kit, since im changing to a z6 timing belt im going to replace the water pump and timing belt tensioner while i have it tore apart.
So will a Timing belt tensioner and water pump from a Z6 work with the B7 or do i ned to order a B7 timing belt Kit, toss the B7 timing belt and order a seperat Z6 timing belt???
In short, DOES?
B7 water pump = Z6 water Pump
B7 Timing belt tensioner = Z6 Timing belt tensioner
thanks
In short, DOES?
thanks
You only have to change the timing belt to a z6.. I had a mini me in a 94 coupe after I blew my z6 up... lol then i went to a JDM ZC vtec in it..
GL on ur build...
GL on ur build...
yeah i know i only HAVE to change the belt but while i have it apart i might as well do it right and replace the tensioner and the water pump, just makes more sense to me to do it instead of diong this work now then blowing it up a month later cuz my water pump takes a ****. I just need to know if a complete Z6 timing belt kit with water pump will work on my B7
corey198807
Oct 13, 2010 12:27 PM
hmtcrxsir
Nov 4, 2005 10:07 PM
