Crank Seal
Old Jan 31, 2009 | 07:40 PM
jacksonww's Avatar
Default Crank Seal
Oil is running down into the pink underlined area as marked in the illistration. The valve cover gasket is not the problem. Is it the crank seal that is probably leaking? Or is it called a Cam seal... Dunno..
I searched for a walk-through for both cam seal and crank seal replacements but came up empty.
Thanks again everyone.
Jack
Old Jan 31, 2009 | 08:08 PM
Jarrat's Avatar
Default Re: Crank Seal
I'd try replacing the CAM seal. If that does not solve your problem then try replacing the crank.
Old Jan 31, 2009 | 08:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Step 1: Remove timing belt covers.
Step 2: To cover your *** line up timing marks and put crank at TDC.
Step 3: Release timing belt tensioner.
Step 4: Remove Timing Belt off of the cam sprocket/s.
Step 5: Remove cam gear from the camshaft.
Step 6: Remove Valve Cover.
Step 7: (This depends on what you have SOHC or DOHC) but from here on you will need to remove the end cap for the camshaft and slip the seal onto the cam. Then put it all back together.
Sorry I am getting tired of typing already lol…
Old Jan 31, 2009 | 09:38 PM
BiGZ's Avatar
Don't forget to coat the seal lip with a lil oil or light grease for inital startup up,and uze a "dab" of HondaBond (or permatex ultra gray) at inside corners of valve cover (nearest the cam capz)
Old Feb 1, 2009 | 06:31 AM
noahrexion's Avatar
The OEM seals will come precoated, so there is no need if it is an OEM seal. Just make sure you take note of how far "in" the old seal is so you know how far "in" to drive the new seal. The crank seal is not your problem if its running down there. It has to be the cam seal if its not the VC because there is nothing else to leak from that spot.
Old Feb 1, 2009 | 09:59 AM
jacksonww's Avatar
Thank you EVERYONE for your help. "This site and it's members are priceless"
Based on everyones input, this job looks pretty cut and dry.
I will tackle this job later on in the week. Looks like I may have to adjust the valves while I am in there.
Thanks again,
Jack
wk9k
Mar 13, 2012 05:45 PM
Civicman86
Jun 22, 2006 10:01 AM
alotawatts
13
Nov 24, 2004 06:00 AM
HamiltonRex
Nov 14, 2004 04:00 PM
david90
Sep 25, 2003 04:37 AM
