cam seal
Old Jan 31, 2009 | 12:18 PM
civicsi18's Avatar
Default cam seal
ok i have a bad oil leak and i figured i would chang the cam seal cause i have read that it cam cause the type of oil leak i have. but when i go to order it from skunk 2 idk how many to put in the quantity box, or if skunk 2 seals them as a set if there are more then one seal.. i have a B16A1 do i have more then one that i should change or do i only have the one right infront of the ditributor. so my main question is how many do i order.
Old Jan 31, 2009 | 01:39 PM
Bondito007's Avatar
Default Re: cam seal
You only need one.
Old Jan 31, 2009 | 01:41 PM
JtriX21's Avatar
You need only 1 because the other cam side has the distributor on it...
Old Jan 31, 2009 | 01:46 PM
DeathLens's Avatar
Only order one. I'm selling one brand new for $35 shipped.
Old Jan 31, 2009 | 04:16 PM
Bondito007's Avatar
Thanks for repeating what I just said fellas. You on top of the game today.
Old Jan 31, 2009 | 04:43 PM
JtriX21's Avatar
Your welcome. Since i explained why, so the '11 users who want to know the same question as this OP can view this thread with the search engine and see why.
Old Jan 31, 2009 | 05:02 PM
Former User's Avatar
If the leak is coming from the driver's side of the engine, then you should also check whether the oil is coming from elsewhere, such as the front crankshaft seal in the oil pump, the valve cover, or the oil pan.
mtdineen
17
Oct 30, 2014 06:23 PM
B18C-YA!
Jun 1, 2006 09:17 PM
Out of every "game"
Apr 16, 2006 02:14 PM
Austin
Jul 26, 2005 08:14 PM
